H1604CG
H1604CG
    MENTECH(铭普光磁)
    SMD,12.7x7.1mm
    SINGLE LAN XFMR 10/100 BASE-T
H1604CG 数据手册
东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. Product Specification for Approval WE ARE PLEASED IN SUBMITTING OUR SAMPLES WITH SPECIFICATION TO YOU FOR APPROVAL. CUSTOMER : DESCRIPTION : 10/100 BASE-T TRANSFORMER MNC P/N : H1604CG VERSION : A0 CUSTOMER P/N : ISSUED DATE : PHOTO OF PRODUCT : WEIGHT : 0.72g MADE IN : CHINA 2020/04/27 APPROVED BY MNC PREPARED BY CHECKED BY APPROVED BY 研发部 研发部 研发部 2020-04-27 2020-04-27 2020-04-27 符晶晶 肖明华 何校民 APPROVED BY CUSTOMER SIGNATURE OR STAMP 1. PLEASE SEND BACK US A COPY OF THE SPECIFICATION WITH YOUR STAMP OR SIGNATURE ONCE THE SAMPLES APPROVED. 2. IT WILL BE DEEMED THE SAMPLES TO BE APPROVED IF NO FEEDBACK. 东莞铭普光磁股份有限公司 TEL: +86-769-86921000 Add:Shipai Town, Dongguan City,Guangdong Province,China FAX: +86-769-81701563 ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. HISTORY FOR REVISED SPECIFICATION Part No. H1604CG INDEX 1. INDEX----------------------------------------------------------------------------------------------------------- 1 2. CHANGE RECORD------------------------------------------------------------------------------------------- 1 3. MECHANICAL-------------------------------------------------------------------------------------------------2 4. SCHEMATIC--------------------------------------------------------------------------------------------------- 3 5. PACKING------------------------------------------------------------------------------------------------------- 4 6. MATERIAL LIST----------------------------------------------------------------------------------------------5 7. RECOMMENDED SOLDERING PROFILE-------------------------------------------------------------- 6 CHANGE RECORD REV. A0 DESCRIPTION (Content or Reason For Change) INITIAL RELEASE DATE REVISOR 2020-04-27 Jingjing Fu ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 1/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. SPECIFICATION Part No. H1604CG A. MECHANICAL : A X Y B H H1604CG Z YYWWX F G SUGGESTED PAD LAYOUT D C I E J 16 SURFACES Note:Laser printing marking YY WW X 1.UNITS:mm/inch. 2.UNLESS OTHERWISE SPECIFIED ALL TOLERANCES ARE: TYPICAL 3.PIN LENGTH DON'T INCLUDE SOLDER POINT Production line code (A to Z) Week Year MILLIMETERS INCHES DIM MIN NOM MAX MIN NOM MAX A 12.20 12.70 13.20 0.480 0.500 0.520 B 6.60 7.10 7.60 0.260 0.280 0.299 C / / 6.40 / / 0.252 D / 8.89 / / 0.350 / E 0.15 0.30 0.45 0.006 0.012 0.018 F / 1.27 / / 0.050 / G / 0.46 / / 0.018 / H 8.90 9.40 9.90 0.350 0.370 0.390 I / 0.70 / / 0.028 / J 0° / 8° 0° / 8° X / 0.76 / / 0.030 / Y / 2.03 / / 0.080 / Z / 10.65 / / 0.419 / ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 2/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. SPECIFICATION Part No. H1604CG B. SCHEMATIC : 1 1CT:1CT 16 TD TX 14 3 5 6 13 1CT:1CT 11 RD RX 8 9 C. ELECTRICAL SPECIFICATION @25℃ ITEM SPECIFICATION TEST CONDITION TEST EQUIPMENT INDUCTANCE : 350uH MIN. 100KHz 0.2V 8mA TH2819XB OR EQU. DC Bias LEAKAGE INDUCTANCE : 0.50uH MAX. 100KHz 0.2V TH2819XB OR EQU. INTERWINDING CAPACITANCE : 50pF TYP. 100KHz 0.2V TH2819XB OR EQU. DC RESISTANCE : 0.9Ω MAX. AT 25 ℃ TOS 8020 OR EQU. TURNS RATIO : 1CT:1CT±5% POLARITY : 1-16,6-11 IN-PHASE INSERTION LOSS : -1.1dB MAX. 0.5-100 MHz -18dB MIN. 0.5-30 MHz RETURN LOSS : CROSS TALK : TH2819XB OR EQU. -18+20*log(f/30)dB MIN. 30.1-60 MHz -12dB MIN. 60.1-80 MHz -35dB MIN. 0.5-40 MHz -33+20*log(f/50)dB MIN. 40.1-100 MHz E5061A OR EQU. E5061A OR EQU. E5061A OR EQU. CMRR : -30dB MIN. 0.5-100MHz E5061A OR EQU. ISOLATION HI-POT :PRI TO SEC 1500VAC 1mA,60S 7152AB OR EQU. OPERATING TEMPERATURE 0℃TO 70℃ ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 3/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. PACKAGE Part No. H1604CG D. PACKING: a. PACKAGING AS BELOW (ONLY FOR A REFERENCE): 0 3 3 Ф 6 . 0 1 Ф CARRIER TAPE COVER TAPE PUT THE REEL INTO THE CARTON ONE REEL b. Q'TY: c. LABEL: 600 PCS PER REEL 8 REELS PER CARTON 4800 PCS PER CARTON REMARK: ABOVE PACKING IS FOR YOUR REFERENCE ONLY, WHICH MIGHT BE CHANGED WITHOUT NOTICE. ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 4/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. MATERIAL LIST Part No. H1604CG E.BOM MATERIAL LIST NO. ITEM MATERIAL RATING SUPPLIER OF MATERIAL UL YEAN SHING Mn-Zn N/A -----ZHONGSHAN CRC ELECTRONICS FACTORY 1 CORE YEAN SHING Ni-Zn ------ N/A ZHONGSHAN CRC ELECTRONICS FACTORY 2 3 4 180℃ Polysol 180 180℃ WH-9100 V-0 WAH HONG INDUSTRIAL CORP E150608 ------ SHENZHEN MINGSCHIN INDUSTRIAL MATERIAL CO.,LTD N/A COPPER WIRE CASE PIN ZHUHAI SUNTEK WIRE CO.,LTD QPN180 C5191 E234867 ELEKTRISOLA(MALAYSIA)SDN. E258243 BHD. ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 5/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. RECOMMENDED REFLOW SOLDERING PROFILE Part No. H1604CG a. RECOMMENDED REFLOW SOLDERING PROFILE: tp Tp Critical Zone TL to TP Ramp up Temperature TL Tsmax tl Tsmin Ramp-down ts Preheat 25℃ tt25 25℃totopeak peak Time TL = 217℃ Tp = 245℃ ts=60-180s Ts max=200℃ Ts min=150℃ tL =60-150s tp=20-40s T25℃ to peak=8min max Ramp up rate=3℃/s max Ramp down rate=6℃/s max *RoHS Compliant *Solder Paste SAC 305 Sn 96.5/Ag 3.0/Cu 0.5 *Silkscreen thickness: 0.15mm Min b. MOISTURE SENSITIVE LEVEL: b.1. LEVEL: 1 b.2. SHELF LIFE: UNLIMITED b.3. STORAGE CONDITION: ≦30℃/85% RH ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 6/6
H1604CG 价格&库存
很抱歉,暂时无法提供与“H1604CG”相匹配的价格&库存,您可以联系我们找货
