H2052DG
H2052DG
    MNC(铭普光磁)
    插件,21.7x10.5mm
    DUAL LAN XFMR 10/100 BASE-T
H2052DG 数据手册
东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. Product Specification for Approval WE ARE PLEASED IN SUBMITTING OUR SAMPLES WITH SPECIFICATION TO YOU FOR APPROVAL. CUSTOMER : DESCRIPTION : 10/100 BASE-T TRANSFORMER MNC P/N : H2052DG VERSION : A0 CUSTOMER P/N : ISSUED DATE : PHOTO OF PRODUCT : WEIGHT : 1.79g MADE IN : CHINA 2020/04/27 APPROVED BY MNC PREPARED BY 研发部 2020-04-27 符晶晶 CHECKED BY APPROVED BY 研发部 研发部 2020-04-27 2020-04-27 肖明华 何校民 APPROVED BY CUSTOMER SIGNATURE OR STAMP 1. PLEASE SEND BACK US A COPY OF THE SPECIFICATION WITH YOUR STAMP OR SIGNATURE ONCE THE SAMPLES APPROVED. 2. IT WILL BE DEEMED THE SAMPLES TO BE APPROVED IF NO FEEDBACK. 东莞铭普光磁股份有限公司 TEL: +86-769-86921000 Add:Shipai Town, Dongguan City,Guangdong Province,China FAX: +86-769-81701563 ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. HISTORY FOR REVISED SPECIFICATION Part No. H2052DG INDEX 1. INDEX---------------------------------------------------------------------------------------------------------1 2. CHANGE RECORD---------------------------------------------------------------------------------------- 1 3. MECHANICAL----------------------------------------------------------------------------------------------2 4. SCHEMATIC-------------------------------------------------------------------------------------------------3 5. PACKING-----------------------------------------------------------------------------------------------------4 6. MATERIAL LIST------------------------------------------------------------------------------------------- 5 7. RECOMMENDED SOLDERING PROFILE------------------------------------------------------------6 CHANGE RECORD REV. A0 DESCRIPTION (Content or Reason For Change) INITIAL RELEASE DATE REVISOR 2020-04-27 Jingjing Fu ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 1/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. SPECIFICATION Part No. H2052DG A. MECHANICAL : I A 1 1 0 2 J 0 1 1 H2052DG B YYWWX K SUGGESTED PAD LAYOUT C E F G H D Note:White ink marking YY WW X 1.UNITS:mm/inch. 2.UNLESS OTHERWISE SPECIFIED ALL TOLERANCES ARE: TYPICAL 3.PIN LENGTH DON'T INCLUDE SOLDER POINT Production line code ( A to Z) Week Year MILLIMETERS INCHES DIM MIN NOM MAX MIN NOM MAX A 20.70 21.20 21.70 0.815 0.835 0.854 B 9.50 10.00 10.50 0.374 0.394 0.413 C / / 6.75 / / 0.266 D 17.50 18.00 18.50 0.689 0.709 0.728 E 2.90 3.20 3.50 0.114 0.126 0.138 F 1.85 2.00 2.15 0.073 0.079 0.085 G 0.40 0.50 0.60 0.016 0.020 0.024 H 7.12 7.62 8.12 0.280 0.300 0.320 I / 0.80 / / 0.031 / J / 7.62 / / 0.300 / K / 18.00 / / 0.709 / ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 2/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. SPECIFICATION Part No. H2052DG B. SCHEMATIC : 1CT:1CT 1 20 2 19 3 4 18 17 5 16 1CT:1CT 1CT:1CT 6 15 7 14 8 9 13 12 10 11 1CT:1CT C. ELECTRICAL SPECIFICATION @25℃ ITEM SPECIFICATION TEST CONDITION TEST EQUIPMENT INDUCTANCE : 350uH MIN. 100KHz 0.2V 8mA TH2819XB OR EQU. DC Bias LEAKAGE INDUCTANCE : 0.50uH MAX. 100KHz 0.2V TH2819XB OR EQU. INTERWINDING CAPACITANCE : 50pF TYP. 100KHz 0.2V TH2819XB OR EQU. DC RESISTANCE : 1.4Ω MAX. AT 25 ℃ TH2819XB OR EQU. TURNS RATIO : 1CT:1CT±5% POLARITY : 1-20,4-17,6-15,9-12 IN-PHASE INSERTION LOSS : -1.1dB MAX. 0.5-100 MHz -18dB MIN. 0.5-30 MHz -18+20*log(f/30)dB MIN. 30.1-60MHz -12dB MIN. 60.1-80MHz -35dB MIN. 0.5-40 MHz -33+20*log(f/50)dB MIN. 40.1-100 MHz -30dB MIN. 0.5-100 MHz 1500VAC 1mA,60S 1650VAC 1mA,6S RETURN LOSS : CROSS TALK : CMRR : ISOLATION HI-POT :PRI TO SEC OPERATING TEMPERATURE TH2819XB OR EQU. E5061A OR EQU. E5061A OR EQU. E5061A OR EQU. E5061A OR EQU. 7152AB OR EQU. 0℃ TO 70℃ ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 3/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. PACKAGE Part No. H2052DG D. PACKING: a. PACKAGING AS BELOW (ONLY FOR A REFERENCE): 530±2 0.5±0.1 E 4.5 B 7.8 A 12.3 C 11.6 D 4.3±0.3 PLUG PLUG SEAL 5g DESICCANT PUT SMALL CARTON 3 4 PUT BIG CARTON 2 2 1 1 b. Q'TY: c. LABEL: 24 PCS PER TUBE 5 TUBES PER BUNDLE (120 PCS) 10 BUNDLES PER BAG (1200 PCS) 1 BAG PER SMALL CARTON 4 SMALL CARTON PER BIG CARTON(4800 PCS) REMARK: ABOVE PACKING IS FOR YOUR REFERENCE ONLY, WHICH MIGHT BE CHANGED WITHOUT NOTICE. ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 4/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. MATERIAL LIST Part No. H2052DG E.BOM MATERIAL LIST NO. ITEM MATERIAL RATING SUPPLIER OF MATERIAL UL ------ YEAN SHING N/A ------ ZHONGSHAN CRC ELECTRONICS FACTORY N/A ------ YEAN SHING N/A ------ ZHONGSHAN CRC ELECTRONICS FACTORY N/A QPN180 180℃ ZHUHAI SUNTEK WIRE CO.,LTD E234867 Polysol 180 180℃ ELEKTRISOLA(MALAYSIA) SDN.BHD. E258243 PF2A5-151J(b) V-0 CHANGSHU SOUTH-EAST PLASTIC CO.,LTD E136137 T378J V-0 CHANG CHUN CHEMICAL(ZHANGZHOU) CO.,LTD. E59481 Mn-Zn 1 CORE Ni-Zn 2 3 COPPER WIRE CASE 4 PIN CP WIRE ------ HIFAM N/A 5 EPOXY 3300A/B ------ DONGGUAN EATTO ELECTRONIC MATERIAL CO.,LTD E218090 ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 5/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. RECOMMENDED SOLDERING PROFILE Part No. H2052DG a. RECOMMENDED WAVE SOLDERING PROFILE: CONDITION: a.1. AVAILABLE FOR ALL THE THROUGH HOLE PARTS a.2. SOLDERING METHOD: WAVE SOLDERING a.3. SOLDER: Sn-0.7Cu a.4. THE RECOMMENDED WAVE SOLDERING CURVE IS AS BELOW b. MOISTURE SENSITIVE LEVEL: b.1. LEVEL: 1 b.2. SHELF LIFE: UNLIMITED b.3. STORAGE CONDITION: ≦30℃/85% RH ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 6/6
H2052DG 价格&库存
很抱歉,暂时无法提供与“H2052DG”相匹配的价格&库存,您可以联系我们找货
