Page 1/5
Data sheet
P/N
310281xx
xx=number of poles
PR016xxVBVC Typ 028
2022/04/05
Version: T
Illustrations
Dimensional drawing
Drill pattern
See enlarged drawings at the end of document
Product specification
• pin header, THR solderable
• centerline 5.08 mm, direction of connection vertical 0°
• fittable without loss of poles
• color black
• Tape & Reel packaging possible
Data sheet
Page 2/5
PR016xxVBVC Typ 028
P/N
310281xx
xx=number of poles
2022/04/05
Version: T
Technical Data
General Data
Solder pin length
min. number of poles
3.4 mm
max. number of poles
24
Insulating material class
CTI 400
clearance/creepage dist.
3.78 mm
Protection category
IP00
Rated current
10 A
Overvoltage category
III
III
II
Pollution degree
3
2
2
Rated voltage
250 V
500 V
500 V
Rated test voltage
4 kV
4 kV
4 kV
2
Approvals
V/A
approval UL - File No.
SEV Reg 130002
300 / 15
E121004
250 V / 4 kV / 10 A / 1.0 mm
Material
insulating material
PA46
flammability class
V0
contact pin material
CuZnPb
contact pin surface
Ni + Ag
Glow-Wire Flammability GWFI
Glow-Wire Flammability GWIT
REACh
compliant
REACh - substance (SVHC)
Lead / 7439-92-1
Climatic Data
upper limit temperature
105 °C
lower limit temperature
-40 °C
general
Tolerance
ISO 2768 -mH
Solderability
Acc. to IPC/JEDEC J-STD-020D-MSL 1
Data sheet
Page 3/5
PR016xxVBVC Typ 028
P/N
310281xx
xx=number of poles
2022/04/05
Version: T
Counterpart of
P/N
Designation
310791
RP026xxIBWU Typ 079
Data sheet
PR016xxVBVC Typ 028
Page 4/5
P/N
310281xx
xx=number of poles
2022/04/05
Version: T
Illustrations
Dimensional drawing
L=(pole size - 1) x centerline + 4.8 mm [0.189]
Data sheet
PR016xxVBVC Typ 028
Page 5/5
P/N
310281xx
xx=number of poles
2022/04/05
Version: T
Illustrations
Drill pattern
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“31028102”相匹配的价格&库存,您可以联系我们找货
