31008104
31008104
    METZCONNECT
    P=5mm
    接线端子 间距:5.00mm
31008104 数据手册
Data sheet RP025xxIBNC Typ 008 Page 1/3 P/N 310081xx xx=number of poles 11/07/2018 Version: P Illustrations Dimensional drawing See enlarged drawings at the end of document Product specification • screw type terminal block, pluggable • centerline 5.00 mm, direction of connection 90° • fittable without loss of poles • color black Data sheet Page 2/3 RP025xxIBNC Typ 008 P/N 310081xx xx=number of poles 11/07/2018 Version: P Technical Data General Data Tightening torque SEV Tightening torque UL 0.5 Nm min. number of poles 2 max. number of poles 24 Insulating material class CTI 600 clearance/creepage dist. 2.3 mm Min. insul. strip length 6 mm Overvoltage category III III II Pollution degree 3 2 2 Rated voltage 100 V 320 V 320 V Rated test voltage 2.5 kV 2.5 kV 2.5 kV 7 lb-in Connection Data rat.wiring solid AWGmax 0.33 mm² - 2.5 mm² / AWG 22 - AWG 12 rat.wiring strand.AWGmax 0.33 mm² - 2.5 mm² / AWG 22 - AWG 12 Approvals extended wiring UL V / A / 22 2.5 mm² Wire range extended to No. 12 AWG solid only. Wire range extended to No. 30 AWG for factory-wiring. Two same size wires No. 22-16 AWG Cu, Sol/Str for field-wiring; No. 30-16 AWG Cu Sol/Str factory-wiring. 300 / 15 / 22 - 14 250 V / 2.5 kV / 10 A Material Glow-Wire Flammability GWFI 960 °C acc. to IEC 60695-2-12 Glow-Wire Flammability GWIT 775 °C acc. to IEC 60695-2-13 REACH - substance (SVHC) Lead / 7439-92-1 Climatic Data upper limit temperature 105 °C lower limit temperature -40 °C Data sheet RP025xxIBNC Typ 008 Page 3/3 P/N 310081xx xx=number of poles 11/07/2018 Version: P Illustrations Dimensional drawing L=(pole size - 1) x centerline + 5 [0.197] Powered by TCPDF (www.tcpdf.org)
31008104
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于工业控制、医疗设备、通信设备等领域。
7. 封装信息:采用DIP6封装方式。
31008104 价格&库存
很抱歉,暂时无法提供与“31008104”相匹配的价格&库存,您可以联系我们找货
