SAC305 No Clean Solder Wire
4900–4917 Technical Data Sheet
ISO 9001:2008 Registered Quality System. Burlington, Ontario, CANADA
4900–4917
SAI Global File: 004008
Description
The 4900–4917 SAC305 No Clean Solder Wire is an electronic grade solder wire.
It uses the predominant lead-free alloy composition and exceeds J-STD-006C and meets ASTM B 32 purity
specifications. It is complemented with a no clean, synthetically refined, splatter-proof resin flux core that
is classified as REL0 according to J-STD-004B. This solder is a great alternative to leaded solders.
The 4900–4917 solders achieve a consistent solder and flux percentage through a state-of-the-art,
extrusion, wire-drawing machine. This machine continually monitors the wire to prevent voids and ensure
consistency, providing a top-grade solder wire.
Benefits & Features
Lead free & no clean
Alloy exceeds J-STD-006C and meets ASTM B 32 purity
requirements
Flux meets J-STD-004B
The resin spreads like rosin-activated flux
Virtually non-splattering
Non-corrosive
Non-conductive residue
Halide free
About 14% longer by weight than leaded solder wires
Suitable for Use in Food Facilities as a Non-Food Chemical—Canadian and NFS recognition
letters available on request
COMPLIANCE
✓ Dobb-Frank (DRC conflict free)
✓ REACH (compliant)
✓ RoHS (compliant)
Wire Sizes Availability
Cat No.
4912
4900
4900
4915
4916
4917
Std. Wire
Gauge
25
21
21
19
18
16
Diameter
0.51
0.81
0.81
1.02
1.27
1.57
mm
mm
mm
mm
mm
mm
0.020
0.032
0.032
0.040
0.050
0.062
in
in
in
in
in
in
Packaging
Sizes
Spool
Pocket Pack
Spool
Spool
Spool
Spool
½ lb
0.6 oz
¼, ½, or 1 lb
¼ or 1 lb
¼ or 1 lb
½ lb
General Flux Parameters
Properties
Value
Residue Removal
Flux Percentage
Flux Feature
Shelf Life
Not required
2.2%
Wets and spreads like a RA type flux and virtually non-splattering.
5y
Page 1 of 5
Date: 13 August 2018 / Ver. 3.01
4900–4917
Flux Core Properties
The synthetically refined resin wets and spreads like a RA flux. This no clean flux is virtually nonsplattering. It gives rise to a hard, non-conductive, and non-corrosive residue.
Physical Properties
Flux Classification
Method
J-STD-004B
EN29454-1
Visual
IPC-TM-650 2.3.13
IPC-TM-650 2.3.32
IPC-TM-650 2.3.33
IPC-TM-650 2.4.46
IPC-TM-650 2.4.47
IPC-TM-650 2.4.48
IPC-TM-650 2.6.15
IPC-TM-650 2.6.3.3
Bellcore GR-78-CORE 13.1.3
Bellcore GR-78-CORE 13.1.4
TGA Analysis
Flux Type
Flux Activity
Halides %(wt)
Solid Flux Color
Softening Point of Flux Extract
Acid Number (mgKOH/g sample)
Copper Mirror
Silver Chromate—Chlorides + Bromides
Solder Spread
Flux Residue Dryness
Spitting of Flux-Cored Wire Solder
Corrosion Test
Surface Insulation Resistance (SIR)
Bellcore (Telecordia)
Electromigration
Post Reflow Residue
Cleaning Requirements
SAC305 Alloy Typical Literature Properties
Physical Properties
Color
Density @26 °C [78 °F]
Tensile Strength
Tensile Yield
Elongation
Shear Strength @20 °C and 0.1 mm/min
Shear Strength @100 °C and 0.1 mm/min
Creep Strength @20 °C and 0.1 mm/min
Hardness
Value a)
Silvery-white metal
7.49 g/cm3
29.7 N/mm2 [4 310 lb/in2]
25.7 N/mm2 [3 720 lb/in2]
27%
27 N/mm2
[3 900 lb/in2]
2
17 N/mm
[2 500 lb/in2]
2
13 N/mm
[1 900 lb/in2]
2
5.0 N/mm
[730 lb/in2]
15 HB
Electrical Properties
Volume Resistivity
Electrical Conductivity b)
Value
13 Ωcm
16.6% IACS
Continued on the next page
Page 2 of 5
Value
REL0
Type 1.1.3
Resin
Low
很抱歉,暂时无法提供与“4900-18G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+223.850661+28.96106
