8461-85ML
8461-85ML
    MGCHEMICALS
    润滑脂 润滑剂 管件,85g(3 盎司) 灰白
8461-85ML 数据手册
Lithium Grease Hydrophobic, Corrosion Inhibiting Lubricant 8461 Technical Data Sheet 8461 Description The 8461 Lithium Grease is a multi-purpose lubricant that provides long superior lubrication and protection against corrosion. As a lubricant, it reduces metal-to-metal friction and wear while retaining it consistency over a wide temperature range. As a corrosion inhibitor, it prevents water and external contaminants from oxidizing metals. Features and Benefits  Corrosion inhibitor  Heat resistant  Easy to use and apply: Smooth buttery cream texture  Long lasting ENVIRONMENT Usage Parameters Properties Shelf Life a) RoHS Compliant Zero-VOC Temperature Ranges Value 5y a) Reported shelf life assumes room temperature storage and unopened container. Properties Constant Service Temperature Storage Temperature Limits Value -40 to 180 °C [-40 to 356 °F] 25 ±5 °C [77 ±9 °F] Principal Components Name Lithium Soap Mineral Oils Zinc Oxide CAS Number 7620-77-1 64741-88-4 1314-13-2 Properties Physical Properties Color Odor Density @25 °C [77 °F] Viscosity Flash Point Boiling Point Auto-ignition Temperature Corrosion Resistant Solubility Filler Base Material Electrical Class Method Visual ASTM D 1475 Cleveland Closed Cup Page 1 of 3 Date: 01 February 2017 / Ver. 1.01 Value White Odorless 0.89 g/mL Cream, semi-solid 185 °C [365 °F] ≥371 °C [≥700 °F] 210 °C [410 °F] Yes Insoluble Lithium Soap Mineral oils Insulator Lithium Grease Hydrophobic, Corrosion Inhibiting Lubricant 8461 Technical Data Sheet 8461 Compatibility Chemical—It is compatible with a wide variety of metal, rubber, and plastic substances. Storage Store within 25 ±5 °C [77 ±9 °F] in dry area. Health, Safety, and Environmental Awareness Please see the 8461 Safety Data Sheet (SDS) for greater details on transportation, storage, handling and other security guidelines. Environmental Impact: The VOC (Volatile Organic Compound) content is 0% by WHMIS and European standards. Health and Safety: The 8461 may cause a mild skin or eye irritation. Wear safety glasses and disposable gloves to avoid exposures. HMIS® RATING NFPA® 704 CODES HEALTH: 1 FLAMMABILITY: 1 PHYSICAL HAZARD: 0 1 1 0 PERSONAL PROTECTION: Approximate HMIS and NFPA Risk Ratings Legend: 0 (Low or none); 1 (Slight); 2 (Moderate); 3 (Serious); 4 (Severe) Application Instructions The performance of the 8461 Lithium Grease depends on surface preparation. Improperly prepared contact surfaces can degrade the oxidation protection, dielectric properties, and lubrication characteristics by trapping contaminants between the surface and the grease. The thickness and coverage should be adjusted to meet your needs. Prerequisites    (Optional) Wear gloves to avoid contaminating the surface and to avoid possible skin irritation. (see 8461 SDS). Clean and dry the surface of the substrate to remove other oils, greases, dust, water, solvents, or any other contaminants. Recommendations: Use MG 824 Isopropyl Alcohol or MG 401B Nu-trol Control Cleaner Equipment    Lint free cloth (for cleaning contact and for wiping excess residue) Spatula or stick application tools (sized appropriately for your application) Isopropyl alcohol or other residue-free organic solvents Page 2 of 3 Date: 01 February 2017 / Ver. 1.01 Lithium Grease Hydrophobic, Corrosion Inhibiting Lubricant 8461 Technical Data Sheet 8461 To apply the grease 1. Wipe the contact with a lint-free cloth. 2. Clean the contacts with isopropyl alcohol or other non-oil based cleaner. 3. Once dry, apply the paste with the application tool to the contact, ensuring adequate coverage and desired thickness. Packaging and Supporting Products Cat. No. 8461-85ML 8461-1P Packaging Tube Tub Net Volume 85 mL 2.9 fl oz 487 mL 1.0 pt Net Weight 85 g 3 oz 487 g 16 oz Packaging Weight 0.9 kg 2.0 lb 0.9 kg 2.0 lb Contact MG Chemicals if custom packaging or sizes are required Supporting Products  Isopropyl Alcohol: Cat. No.824 Technical Support Contact us regarding any questions, improvement suggestions, or problems with this product. Application notes, instructions, and FAQs are located at www.mgchemicals.com. Email: support@mgchemicals.com Phone: +(1) 800-340-0772 (Canada, Mexico & USA) +(1) 905-331-1396 (International) Fax: +(1) 905-331-2862 or +(1) 800-340-0773 Mailing address: Manufacturing & Support 1210 Corporate Drive Burlington, Ontario, Canada L7L 5R6 Head Office 9347–193rd Street Surrey, British Columbia, Canada V4N 4E7 Warranty M.G. Chemicals Ltd. warranties this product for 12 months from the date of purchase by the end user. M.G. Chemicals Ltd. makes no claims as to shelf life of this product for the warranty. The liability of M.G. Chemicals Ltd. whether based on its warranty, contracts, or otherwise shall in no case include incidental or consequential damage. Disclaimer This information is believed to be accurate. It is intended for professional end users having the skills to evaluate and use the data properly. M.G. Chemicals Ltd. does not guarantee the accuracy of the data and assumes no liability in connection with damages incurred while using it. Page 3 of 3 Date: 01 February 2017 / Ver. 1.01
8461-85ML 价格&库存
很抱歉,暂时无法提供与“8461-85ML”相匹配的价格&库存,您可以联系我们找货
8461-85ML
  • 1+149.41595
  • 25+136.42377
  • 50+125.59103
库存:40
