RTV167-85ML
RTV167-85ML
    MGCHEMICALS
    SIL
    ADHESIVE SEALANT SIL HI STRENGTH
RTV167-85ML 数据手册
RTV Silicones >> High strength electronics grade >> Light grey, 1 Part Paste, RTV Silicone Adhesive Sealant RTV Silicones by Technical Support for RTV Silicones 1-Part Adhesive Sealant RTV167 RTV Number... Jump to Product Number Product Number... Accessories Adhesives 1-800-255-8886 Primary Characteristics Light Gray Paste High strength electronics Non-corrosive Alkoxy neutral cure MIL-A-46146, group 1, type 1 UL HB recognition UL File No. E36952 Brushes Cleaners / Degreasers Contact Cleaners Desoldering Braid Dusters & Circuit Coolers Excellent in areas that require an extra strength sealing and bonding. Non-corrosive to electronic metals, including copper and brass. Can be applied to vertical or overhead surfaces. Retains elastomeric properties for long periods at temperatures from -60°C to 205°C (75°F to 400°F) and for short periods up to 250°C (500°F). Excellent electrical insulating properties. This product meets Military spec. MIL-A-46146 and is UL HB recognized. EMI / RFI Shielding Epoxies M.G. Chemicals Disclaimer for RTV Silicones > Locate Distributor > Quick Links MSDS Specifications Available Sizes Related products: Available Sizes RTV160 White Flux and Flux Remover Glass & Screen Cleaners Catalog Number Sizes Available Description Case Qty RTV162 White Isopropyl Alcohol RTV167-85ML 85 mL (2.8 oz) Tube 12 TSE397C Clear Lead Free Solder RTV167-300ML 300mL (10 oz) Cartridge 24 TSE399C Clear Lubricants Potting & Encapsulating Protective Coatings Specifications Selection Guide Pens One Part Chart Prototyping Materials Two Part Chart RTV Silicones Use Adhesive Sealant Soldering/desoldering Special Feature High tensile strength Specialized Cleaners Standards MIL-A-46146, group 1, type 1 Swabs Thermal Management Thermally Conductive Adhesives Wipes UL File no. E-36952 Cross Reference RTV167 General Purpose Aerospace Marine Uncured Properties Consistency Paste High Performance Assembly Color Grey Electronics Specific Gravity 1.12 Thermal Conductivity Tack Free Time 4 hours High Temperature Cure through time 48 hours Useful Temp. Range -60°C to 205°C (-75°F to 400°F) Low Temperature Cured Properties - MECHANICAL Hardness 37 (Shore A) Tensile Strength 5.49 MPa (800 psi) Elongation 600% Peel Strength 10 kg/cm 80 lb/in Cured Properties - ELECTRICAL Volume Resistivity 3 x 1015 ohm · cm Dielectric Strength 19.7 kV/mm 500 V/mil Dielectric Constant Cured Properties - THERMAL http://www.mgchemicals.com/products/167.html (1 of 2)11/24/2008 8:02:59 AM 2.8 @ 60 Hz Google Search MG RTV Silicones >> High strength electronics grade >> Light grey, 1 Part Paste, RTV Silicone Adhesive Sealant Thermal Conductivity 0.21 W/m · °K Brittle Point -60°C (-75°F) Thermal Expansion 27 x 10-5 (°C)-1 Other Viscosity (@ 25°C) Return to top ^ © 2000 - 2007 MG Chemicals. All rights reserved. Site Map Terms & Conditions Contact Us web site design by offbeat studio http://www.mgchemicals.com/products/167.html (2 of 2)11/24/2008 8:02:59 AM 180 g/min
RTV167-85ML 价格&库存
很抱歉,暂时无法提供与“RTV167-85ML”相匹配的价格&库存,您可以联系我们找货
