RTV5818-300ML
RTV5818-300ML
    MGCHEMICALS
    ADHESIVE SEALANT SIL FAST CURE
RTV5818-300ML 数据手册
RTV Silicones >> One Part, Clear, RTV Silicone Adhesive Sealant >> Fast cure RTV Silicones by 1-Part Adhesive Sealant RTV5818 RTV Number... Technical Support for RTV Silicones 1-800-255-8886 M.G. Chemicals Disclaimer for RTV Silicones > Jump to Product Number Product Number... Accessories Adhesives Brushes Primary Characteristics Translucent Paste Fast cure Modified alkoxy (neutral) cure UL HB Recognition UL File No. E36952 Cleaners / Degreasers Fast curing, paste adhesive designed to provide quick initial adhesion build. Assembly applications requiring high productivity; suited for applicateions in confined spaces. Contact Cleaners Desoldering Braid Dusters & Circuit Coolers EMI / RFI Shielding Epoxies Flux and Flux Remover Glass & Screen Cleaners Isopropyl Alcohol Lead Free Solder Features primerless adhesion to many metals, plastics, masonry, wood, glass and ceramics. Not recommended for use on polycarbonates and acrylics. Also good for marine applications. UL HB Recognition. Quick Links MSDS Specifications Available Sizes Related products: Available Sizes 1035 Translucent Catalog Number Sizes Available Description RTV5818-300ML 300mL (10 oz) Cartridge Selection Guide One Part Chart Lubricants Potting & Encapsulating Locate Distributor > Specifications Two Part Chart Protective Coatings Pens Use Prototyping Materials RTV Silicones Soldering/desoldering Specialized Cleaners Swabs Thermal Management Thermally Conductive Adhesives Wipes Adhesive Sealant Marine Application General Purpose Special Features High strength, non-corrosive Aerospace Cross Reference 1035, RTV5812, RTV5813 Uncured Properties Consistency Paste Color Translucent Specific Gravity 1.04 Tack Free Time 15 min Cure Through Time 12 - 24 hours Useful Temp. Range -60°C to 204°C (-75°F to 399 °F) Marine High Performance Assembly Electronics Thermal Conductivity High Temperature Low Temperature Cured Properties - MECHANICAL Hardness 21 (Shore A) Tensile Strength 1.896 MPa (275 psi) Elongation 500% Tear Strength 7.1 kg/cm (40 lb/in) Peel Strength 8 kg/cm (47 lb/in) Cured Properties - ELECTRICAL Volume Resistivity 2 x 1015 ohm · cm Dielectric Strength 16.8 kV/mm 425 V/mil Dielectric Constant Cured Properties - THERMAL http://www.mgchemicals.com/products/5818.html (1 of 2)11/24/2008 8:08:53 AM 2.8 @ 100 Hz Google Search MG RTV Silicones >> One Part, Clear, RTV Silicone Adhesive Sealant >> Fast cure Thermal Conductivity 0.06 W/m · °K Brittle Point -60°C (-75°F) Thermal Expansion 3.0 x 10-4 mm/mm/°C Other Viscosity (@ 25°C) 480 g/min Return to top ^ © 2000 - 2007 MG Chemicals. All rights reserved. Site Map Terms & Conditions Contact Us web site design by offbeat studio http://www.mgchemicals.com/products/5818.html (2 of 2)11/24/2008 8:08:53 AM
RTV5818-300ML 价格&库存
很抱歉,暂时无法提供与“RTV5818-300ML”相匹配的价格&库存,您可以联系我们找货
