RTV615-1P
RTV615-1P
    MGCHEMICALS
    POTTING COMPOUND CLEAR FLOWABLE
RTV615-1P 数据手册
RTV Silicones >> Optically clear >> 2 part, pourable, Red, 2 Part Flowable Potting and Encapsulating Compound RTV Silicones by RTV Number... 2-Part Potting/Encapsulating Compound RTV615 Technical Support for RTV Silicones 1-800-255-8886 M.G. Chemicals Disclaimer for RTV Silicones > Jump to Product Number Product Number... Accessories Adhesives Brushes Primary Characteristics Optically Clear Easily pourable Addition cure Primer required FDA Approved Cleaners / Degreasers Contact Cleaners Desoldering Braid Dusters & Circuit Coolers EMI / RFI Shielding Epoxies Flux and Flux Remover Use for: Solar cell potting Optical instruments Applications requiring visual identification of potted assemblies Food applications Glass & Screen Cleaners Isopropyl Alcohol Lead Free Solder Lubricants Potting & Encapsulating Excellent for potting solar cells for maximum light transmission and electronic assemblies where component identification is desirable. This two part silicone is supplied with a curing agent. Primer required. Cures at room temperature. Has low viscosity allowing easy flow in and around complex parts, providing excellent electrical insualtion and shock resistance. Clarity permits visual inspection foreasy indentification and repair of encapsulated parts. Excellent retention of elastomeric properties at temperatures up to 204°C (400°F). Will cure in deep sections or enclosed assemblies without exotherm and with low shrinkage. Can be used in food contact applications where FDA 21 CFR 177.2600 regulations apply. Locate Distributor > Quick Links MSDS Catalyst options/MSDS Primer options/MSDS Specifications Available Sizes Related products: RTV103 Black RTV108 Translucent RTV109 Aluminum Protective Coatings Pens Available Sizes Prototyping Materials Selection Guide RTV Silicones Catalog Number Sizes Available Description One Part Chart Soldering/desoldering RTV615-1P 1 pint 1 lb kit Two Part Chart Specialized Cleaners RTV615-1G 1 gallon 10 lbs. kit RTV615-5G 5 gallon 44 lbs. kit Swabs Thermal Management Thermally Conductive Adhesives Wipes RTV615 requires a primer. Visit our primer guide for details. General Purpose Aerospace Marine Specifications High Performance Assembly Use Adhesive Sealant Special Feature High tensile strength Optically Clear Standards FDA 21CFR 177.2600 Cross Reference RTV615 Electronics Thermal Conductivity High Temperature Low Temperature Uncured Properties Consistency Easily pourable Color Optical clear Specific Gravity 1.05 Tack Free Time 4 hours Cure Through Time 6 - 7 days @ 25°C 15 min @ 150°C Useful Temp. Range -60°C to 205°C (-75°F to 400°F) Cured Properties - MECHANICAL Hardness http://www.mgchemicals.com/products/615.html (1 of 2)11/24/2008 8:04:44 AM 44 (Shore A) Google Search MG RTV Silicones >> Optically clear >> 2 part, pourable, Red, 2 Part Flowable Potting and Encapsulating Compound Tensile Strength 6.37 MPa (920 psi) Elongation 120% Cured Properties - ELECTRICAL Volume Resistivity 1.8 x 1015 ohm · cm Dielectric Strength 19.7 kV/mm 500 V/mil Dielectric Constant 2.7 @ 1000 Hz Cured Properties - THERMAL Thermal Conductivity 0.19 W/m · °K Brittle Point -60°C (-75°F) Thermal Expansion 27 x 10-5 (°C)-1 Other Viscosity (@ 25°C) 4,000 cps Mix Ratio (by weight) 10 : 1 Pot Life 4 hours Index of Refraction 1.406 Return to top ^ © 2000 - 2007 MG Chemicals. All rights reserved. Site Map Terms & Conditions Contact Us web site design by offbeat studio http://www.mgchemicals.com/products/615.html (2 of 2)11/24/2008 8:04:44 AM
RTV615-1P 价格&库存
很抱歉,暂时无法提供与“RTV615-1P”相匹配的价格&库存,您可以联系我们找货
