RTV Silicones >> White, One Part RTV Silicone Adhesive Sealant >> High Performance Assembly - RoHS Compliant
RTV Silicones by
1-Part Adhesive Sealant RTV102
RTV Number...
Jump to Product Number
Product Number...
Accessories
Adhesives
Brushes
1-800-255-8886
Primary Characteristics
White Paste
High Strength
High performance assembly
Acetoxy cure
Meets MIL-A-46106
UL File no. E-36952
FDA 21 CFR 177.2600
Cleaners / Degreasers
Contact Cleaners
Desoldering Braid
Dusters & Circuit Coolers
Excellent for insulating, sealing, bonding and
formed-in-place gaskets. Can be applied to
vertical and overhead surfaces. Not for use
in delicate electrical and electronic
applications in which corrosion of copper,
brass, or other sensitive metals is
undesirable. Can be used in food contact
applications where FDA regulations apply.
Reference CDS4319 "Food Contact
Applications", "Silicone Rubber Compounds."
EMI / RFI Shielding
Epoxies
Technical Support
for RTV Silicones
M.G. Chemicals Disclaimer
for RTV Silicones >
Locate Distributor >
Quick Links
MSDS
Specifications
Available Sizes
Related products:
Available Sizes
RTV103 Black
Flux and Flux Remover
Glass & Screen Cleaners
Catalog No.
Size
Description
Isopropyl Alcohol
RTV102-85ML
2.8 oz
Tube
Lead Free Solder
RTV102-300ML
10.1 oz
Cartridge
RTV108 Translucent
RTV109 Aluminum
Lubricants
Potting & Encapsulating
Selection Guide
Specifications
One Part Chart
Protective Coatings
Pens
Prototyping Materials
RTV Silicones
Soldering/desoldering
Two Part Chart
Use
Adhesive Sealant
Special Feature
High tensile strength
Standards
FDA 21CFR 177.2600
MIL-A-46106
Specialized Cleaners
Swabs
Thermal Management
Thermally Conductive
Adhesives
Cross Reference
Wipes
Uncured Properties
UL Recognized
Aerospace
UL File No. E-36952
Marine
UL 94 HB
RTV 102, DC 732
Electronics
Thermal Conductivity
Consistency
Paste
Color
White
Specific Gravity
1.05
Tack Free Time
20 min
Cure Through Time
( 77°F / 50% relative humidity / 1/8" thick)
7 days
Cure Time
(@ 77°F /50% relative humidity)
3 days
Useful Temp. Range
-60°C to 205°C
(-75°F to 400°F)
Cured Properties - MECHANICAL
Hardness
30 (Shore A)
Tensile Strength
2.8 kg/cm2 (400 psi)
Elongation
450%
Tear Strength
8 kg/cm
45 lb/in
Peel Strength
7 kg/cm
40 lb/in
http://www.mgchemicals.com/products/102.html (1 of 2)11/24/2008 7:27:41 AM
General Purpose
High Temperature
Low Temperature
Google Search MG
Cured Properties - ELECTRICAL
Volume Resistivity
3 x 1015 ohm · cm
Dielectric Strength
20 kV/mm
500 V/mil
Dielectric Constant
2.8 @ 60 Hz
Cured Properties - THERMAL
0.5 x 10-4 cal/sec/cm2
Brittle Point
-60°C (-75°F)
Thermal Expansion
7 x 10-5 (°C)-1
Other
Viscosity (@ 25°C)
400 g/min
Return to top ^
© 2000 - 2007 MG Chemicals. All rights reserved. Site Map Terms & Conditions Contact Us
web site design by offbeat studio
http://www.mgchemicals.com/products/102.html (2 of 2)11/24/2008 7:27:41 AM
很抱歉,暂时无法提供与“RTV102-300ML”相匹配的价格&库存,您可以联系我们找货
