RTV103-300ML
RTV103-300ML
    MGCHEMICALS
    SIL
    ADHESIVE SEALANT SIL BLACK PASTE
RTV103-300ML 数据手册
RTV Silicones >> Black One Part RTV Silicone Adhesive Sealant >> High Performance Assembly RTV Silicones by 1-Part Adhesive Sealant RTV103 RTV Number... Jump to Product Number Product Number... Accessories Adhesives Brushes 1-800-255-8886 Primary Characteristics Black Paste High Strength High performance assembly Acetoxy cure Meets MIL-A-46106 UL File no. E-36952 FDA 21 CFR 177.2600 Cleaners / Degreasers Contact Cleaners Desoldering Braid Dusters & Circuit Coolers Excellent for insulating, sealing, bonding and formed-in-place gaskets. Can be applied to vertical and overhead surfaces. Not for use in delicate electrical and electronic applications in which corrosion of copper, brass, or other sensitive metals is undesirable. Can be used in food contact applications where FDA regulations apply. Reference CDS4319 "Food Contact Applications", "Silicone Rubber Compounds." EMI / RFI Shielding Epoxies Technical Support for RTV Silicones M.G. Chemicals Disclaimer for RTV Silicones > Locate Distributor > Quick Links MSDS Specifications Available Sizes Related products: Available Sizes RTV102 White Flux and Flux Remover Glass & Screen Cleaners Catalog No. Size Description Isopropyl Alcohol RTV103-85ML 2.8 oz Tube Lead Free Solder RTV103-300ML 10.1 oz Cartridge RTV108 Translucent RTV109 Aluminum Lubricants Potting & Encapsulating Selection Guide Specifications One Part Chart Protective Coatings Pens Prototyping Materials RTV Silicones Soldering/desoldering Two Part Chart Use Adhesive Sealant Special Feature High tensile strength Standards FDA 21CFR 177.2600 MIL-A-46106 Specialized Cleaners Swabs Thermal Management Thermally Conductive Adhesives Cross Reference Wipes Uncured Properties UL Recognized Aerospace UL File No. E-36952 Marine UL 94 HB High Performance Assembly RTV 102, DC 732 Electronics Thermal Conductivity Consistency Paste Color Black Specific Gravity 1.05 Tack Free Time 20 min Cure Through Time ( 77°F / 50% relative humidity / 1/8" thick) 7 days Cure Time (@ 77°F /50% relative humidity) 3 days Useful Temp. Range -60°C to 205°C (-75°F to 400°F) Cured Properties - MECHANICAL Hardness 30 (Shore A) Tensile Strength 2.8 kg/cm2 (400 psi) Elongation 450% Tear Strength 8 kg/cm 45 lb/in Peel Strength 7 kg/cm 40 lb/in http://www.mgchemicals.com/products/103.html (1 of 2)11/24/2008 7:32:32 AM General Purpose High Temperature Low Temperature Google Search MG RTV Silicones >> Black One Part RTV Silicone Adhesive Sealant >> High Performance Assembly Cured Properties - ELECTRICAL Volume Resistivity 3 x 1015 ohm · cm Dielectric Strength 20 kV/mm 500 V/mil Dielectric Constant 2.8 @ 60 Hz Cured Properties - THERMAL Thermal Conductivity 0.5 x 10-4 cal/sec/cm2 Brittle Point -60°C (-75°F) Thermal Expansion 7 x 10-5 (°C)-1 Other Viscosity (@ 25°C) 400 g/min Return to top ^ © 2000 - 2007 MG Chemicals. All rights reserved. Site Map Terms & Conditions Contact Us web site design by offbeat studio http://www.mgchemicals.com/products/103.html (2 of 2)11/24/2008 7:32:32 AM
RTV103-300ML 价格&库存
很抱歉,暂时无法提供与“RTV103-300ML”相匹配的价格&库存,您可以联系我们找货
