RTV106-85ML
RTV106-85ML
    MGCHEMICALS
    SIL
    ADHESIVE SEALANT SIL RED PASTE
RTV106-85ML 数据手册
RTV Silicones >> One Part RTV Silicone Adhesive Sealant >> High Temp Red, High Performance Assembly RTV Silicones by 1-Part Adhesive Sealant RTV106 RTV Number... Jump to Product Number Product Number... Accessories Adhesives Technical Support for RTV Silicones 1-800-255-8886 Primary Characteristics Red Paste High Temperature rated Acetoxy cure Meets MIL-A-46106 UL File no. E-36952 FDA 21 CFR 177.2600 Brushes Cleaners / Degreasers Contact Cleaners Desoldering Braid Dusters & Circuit Coolers Excellent for insulating, sealing, bonding and formed-in-place gaskets. Can be applied to vertical and overhead surfaces. Not for use in delicate electrical and electronic applications in which corrosion of copper, brass, or other sensitive metals is undesirable. Can be used in food contact applications where FDA regulations apply. Reference CDS4319 "Food Contact Applications", "Silicone Rubber Compounds." M.G. Chemicals Disclaimer for RTV Silicones > Locate Distributor > Quick Links MSDS Specifications Available Sizes EMI / RFI Shielding Epoxies Available Sizes Related Products: Flux and Flux Remover Glass & Screen Cleaners Catalog No. Size Description Isopropyl Alcohol RTV106-85ML 2.8 oz Tube Lead Free Solder RTV106-300ML 10.1 oz Cartridge RTV116 RTV159 Lubricants Potting & Encapsulating Protective Coatings Selection Guide Specifications One Part Chart Two Part Chart Pens Prototyping Materials Use Adhesive Sealant RTV Silicones Special Feature High Temperature Standards FDA 21CFR 177.2600 MIL-A-46106 UL Recognized UL File No. E-36952 UL 95 HB Soldering/desoldering Specialized Cleaners Swabs Thermal Management Thermally Conductive Adhesives Wipes Cross Reference RTV106, DC732 Color Specific Gravity Paste Red 1.07 Tack Free Time 25 min Cure Through Time ( 77°F / 50% relative humidity / 1/8" thick) 24 hours Cure Time (@ 77°F /50% relative humidity) 3 days Useful Temp. Range -60°C to 260°C (-75°F to 500°F) Cured Properties - MECHANICAL Hardness 30 (Shore A) Tensile Strength 2.55 MPa (375 psi) Elongation 400% Tear Strength 7 kg/cm (40 lb/in) Peel Strength 7 kg/cm (40 lb/in) Cured Properties - ELECTRICAL http://www.mgchemicals.com/products/106.html (1 of 2)11/24/2008 7:48:14 AM Aerospace Marine High Performance Assembly Electronics Uncured Properties Consistency General Purpose Thermal Conductivity High Temperature Low Temperature Google Search MG RTV Silicones >> One Part RTV Silicone Adhesive Sealant >> High Temp Red, High Performance Assembly Volume Resistivity 3 x 1014 ohm · cm Dielectric Strength 19.7 kV/mm (500 V/mil) Dielectric Constant 2.8 @ 60 Hz Cured Properties - THERMAL Thermal Conductivity 0.2092 W/m · °K Brittle Point -60°C (-75°F) Thermal Expansion 27 x 10-5 (°C)-1 Other Viscosity (@ 25°C) 400 g/min Return to top ^ © 2000 - 2007 MG Chemicals. All rights reserved. Site Map Terms & Conditions Contact Us web site design by offbeat studio http://www.mgchemicals.com/products/106.html (2 of 2)11/24/2008 7:48:14 AM
RTV106-85ML 价格&库存
很抱歉,暂时无法提供与“RTV106-85ML”相匹配的价格&库存,您可以联系我们找货
