RTV Silicones >> One Part RTV Silicone Adhesive Sealant >> High Temp Red, High Performance Assembly
RTV Silicones by
1-Part Adhesive Sealant RTV106
RTV Number...
Jump to Product Number
Product Number...
Accessories
Adhesives
Technical Support
for RTV Silicones
1-800-255-8886
Primary Characteristics
Red Paste
High Temperature rated
Acetoxy cure
Meets MIL-A-46106
UL File no. E-36952
FDA 21 CFR 177.2600
Brushes
Cleaners / Degreasers
Contact Cleaners
Desoldering Braid
Dusters & Circuit Coolers
Excellent for insulating, sealing, bonding and
formed-in-place gaskets. Can be applied to
vertical and overhead surfaces. Not for use
in delicate electrical and electronic
applications in which corrosion of copper,
brass, or other sensitive metals is
undesirable. Can be used in food contact
applications where FDA regulations apply.
Reference CDS4319 "Food Contact
Applications", "Silicone Rubber Compounds."
M.G. Chemicals Disclaimer
for RTV Silicones >
Locate Distributor >
Quick Links
MSDS
Specifications
Available Sizes
EMI / RFI Shielding
Epoxies
Available Sizes
Related Products:
Flux and Flux Remover
Glass & Screen Cleaners
Catalog No.
Size
Description
Isopropyl Alcohol
RTV106-85ML
2.8 oz
Tube
Lead Free Solder
RTV106-300ML
10.1 oz
Cartridge
RTV116
RTV159
Lubricants
Potting & Encapsulating
Protective Coatings
Selection Guide
Specifications
One Part Chart
Two Part Chart
Pens
Prototyping Materials
Use
Adhesive Sealant
RTV Silicones
Special Feature
High Temperature
Standards
FDA 21CFR 177.2600
MIL-A-46106
UL Recognized
UL File No. E-36952
UL 95 HB
Soldering/desoldering
Specialized Cleaners
Swabs
Thermal Management
Thermally Conductive
Adhesives
Wipes
Cross Reference
RTV106, DC732
Color
Specific Gravity
Paste
Red
1.07
Tack Free Time
25 min
Cure Through Time
( 77°F / 50% relative humidity / 1/8" thick)
24 hours
Cure Time
(@ 77°F /50% relative humidity)
3 days
Useful Temp. Range
-60°C to 260°C
(-75°F to 500°F)
Cured Properties - MECHANICAL
Hardness
30 (Shore A)
Tensile Strength
2.55 MPa (375 psi)
Elongation
400%
Tear Strength
7 kg/cm (40 lb/in)
Peel Strength
7 kg/cm (40 lb/in)
Cured Properties - ELECTRICAL
http://www.mgchemicals.com/products/106.html (1 of 2)11/24/2008 7:48:14 AM
Aerospace
Marine
Electronics
Uncured Properties
Consistency
General Purpose
Thermal Conductivity
High Temperature
Low Temperature
Google Search MG
Volume Resistivity
3 x 1014 ohm · cm
Dielectric Strength
19.7 kV/mm (500 V/mil)
Dielectric Constant
2.8 @ 60 Hz
Cured Properties - THERMAL
0.2092 W/m · °K
Brittle Point
-60°C (-75°F)
Thermal Expansion
27 x 10-5 (°C)-1
Other
Viscosity (@ 25°C)
400 g/min
Return to top ^
© 2000 - 2007 MG Chemicals. All rights reserved. Site Map Terms & Conditions Contact Us
web site design by offbeat studio
http://www.mgchemicals.com/products/106.html (2 of 2)11/24/2008 7:48:14 AM
很抱歉,暂时无法提供与“RTV106-300ML”相匹配的价格&库存,您可以联系我们找货
