RTV118-85ML
RTV118-85ML
    MGCHEMICALS
    SIL
    ADHESIVE SEAL SIL TRANS FLOWABLE
RTV118-85ML 数据手册
RTV Silicones >> Clear, Flowable, One Part RTV Silicone Adhesive Sealant >> Thin Section Potting RTV Silicones by Technical Support for RTV Silicones 1-Part Adhesive Sealant RTV118 RTV Number... 1-800-255-8886 M.G. Chemicals Disclaimer for RTV Silicones > Jump to Product Number Product Number... Accessories Adhesives Primary Characteristics Clear Flowable Acetoxy cure Food Applications FDA 21 CFR 177.2600 Brushes Cleaners / Degreasers Contact Cleaners Desoldering Braid Dusters & Circuit Coolers EMI / RFI Shielding Epoxies Flux and Flux Remover Glass & Screen Cleaners Isopropyl Alcohol Lead Free Solder Lubricants Potting & Encapsulating Excellent for thin section potting, filling small surface voids, self leveling protective coatings. Will flow into small crevices and hard to reach places. Not for use in delicate electrical and electronic applications in which corrosion of copper, brass, or other sensitive metals is undesirable. Can be used in food contact applications where FDA 21 CFR 177.2600 regulations apply. Reference CDS4319 "Food Contact Applications", "Silicone Rubber Compounds." Locate Distributor > Quick Links MSDS Specifications Available Sizes Related products: RTV112 White Available Sizes Catalog Number Sizes Available Description RTV118-85ML 85 mL Tube RTV118-300ML 300 mL Cartridge Selection Guide One Part Chart Two Part Chart Protective Coatings Pens Prototyping Materials RTV Silicones Specifications General Purpose Use Adhesive Sealant Aerospace Specialized Cleaners Special Feature High Performance Marine Swabs Standards FDA 21CFR 177.2600 High Performance Assembly Thermal Management MIL-A-46106, group 1, type 2 Electronics Thermally Conductive Adhesives UL File No. E-36952 Thermal Conductivity RTV112 High Temperature Soldering/desoldering Wipes Cross Reference Low Temperature Uncured Properties Consistency Flowable Color Clear Specific Gravity 1.05 Tack Free Time 20 min Cure Time (77°F /50% relative humidity) 7 days Useful Temp. Range -60°C to 205°C (-75°F to 400°F) Cured Properties - MECHANICAL Hardness 25 (Shore A) Tensile Strength 2.20 MPa (325 psi) Elongation 325% Peel Strength 3 kg/cm (15 lb/in) Cured Properties - ELECTRICAL Volume Resistivity 6 x 1014 ohm · cm Dielectric Strength 16 kV/mm (400 V/mil) http://www.mgchemicals.com/products/118.html (1 of 2)11/24/2008 7:58:47 AM Google Search MG RTV Silicones >> Clear, Flowable, One Part RTV Silicone Adhesive Sealant >> Thin Section Potting Dielectric Constant 2.8 @ 60 Hz Cured Properties - THERMAL Thermal Conductivity 0.21 W/m · °K Brittle Point -60°C (-75°F) Thermal Expansion 27 x 10-5 (°C)-1 Other Viscosity (@ 25°C) 20,000 cps Return to top ^ © 2000 - 2007 MG Chemicals. All rights reserved. Site Map Terms & Conditions Contact Us web site design by offbeat studio http://www.mgchemicals.com/products/118.html (2 of 2)11/24/2008 7:58:47 AM
RTV118-85ML 价格&库存
很抱歉,暂时无法提供与“RTV118-85ML”相匹配的价格&库存,您可以联系我们找货
