RTV12C-1P
RTV12C-1P
    MGCHEMICALS
    POTTING COMPOUND CURING AGENT
RTV12C-1P 数据手册
RTV Silicones >> Primerless Adhesion >> Clear, 2 Part Flowable Potting and Encapsulating Compound RTV Silicones by RTV Number... Technical Support for RTV Silicones 2-Part Potting/Encapsulating Compound RTV12 1-800-255-8886 M.G. Chemicals Disclaimer for RTV Silicones > Jump to Product Number Product Number... Accessories Adhesives Brushes Cleaners / Degreasers Primary Characteristics Clear flowable Primerless adhesion Condensation cure General purpose potting Room temp. cure Requires parts A and C A clear, two component, low viscosity potting compound that cures at room temperature to a soft pliable rubber. Will cure in deep sections. Designed to acheive primerless adhesion to many substrates, including metals, plastics, and ceramics. The excellent electrical properties make it a candidate material for both high and low voltage electrical assemblies. Cushions against mechanical shock and vibration. RTV12 is clear enough to allow visual observation of components during pouring. After cure, the clarity lends to easy identification, repair and replacement of components. Contact Cleaners Desoldering Braid Dusters & Circuit Coolers EMI / RFI Shielding Epoxies Flux and Flux Remover Glass & Screen Cleaners Use for : General purpose potting requiring clear, room temp. cure Applications where primerless adhesion is desired Isopropyl Alcohol Lead Free Solder Quick Links MSDS Catalyst options/MSDS Primer options/MSDS Specifications Available Sizes Related products: RTV103 Black RTV108 Translucent RTV109 Aluminum Lubricants Potting & Encapsulating Locate Distributor > Available Sizes Protective Coatings Catalog Number Sizes Available Description Prototyping Materials RTV12A-1G 9.5 lbs. Pail Selection Guide RTV Silicones RTV12C-1P 1 pint Catalyst for RTV12, pail One Part Chart Pens Two Part Chart Soldering/desoldering Specialized Cleaners Swabs Thermal Management Thermally Conductive Adhesives Wipes Specifications Use General Purpose Potting General Purpose Special Feature Cushions against mechanical shock Aerospace Cross Reference RTV12 Marine High Performance Assembly Uncured Properties Electronics Consistency Flowable Thermal Conductivity Color Clear (translucent) High Temperature Specific Gravity 1.00 Low Temperature Pot Life (@ 25°C / 77°F) 1.6 hours Cure Through Time 24 hours Useful Temp. Range -54°C to 204°C (-75°F to 400°F) Cured Properties - MECHANICAL Hardness 18 (Shore A) Elongation 20 0% Cured Properties - ELECTRICAL 13 Volume Resistivity 1 x 10 Dielectric Strength 400 V/mil Dielectric Constant 3.0 @ 1000 Hz http://www.mgchemicals.com/products/12.html (1 of 2)11/24/2008 5:28:25 AM ohm · cm Google Search MG RTV Silicones >> Primerless Adhesion >> Clear, 2 Part Flowable Potting and Encapsulating Compound Cured Properties - THERMAL Thermal Conductivity 0.17 W/m · °K Brittle Point -60°C (-75°F) Thermal Expansion -29 x 10 -5 Other Viscosity (@ 25°C) 1,300 cps Mix Ratio (by weight) 20:1 Return to top ^ © 2000 - 2007 MG Chemicals. All rights reserved. Site Map Terms & Conditions Contact Us web site design by offbeat studio http://www.mgchemicals.com/products/12.html (2 of 2)11/24/2008 5:28:25 AM (°C) -1
RTV12C-1P 价格&库存
很抱歉,暂时无法提供与“RTV12C-1P”相匹配的价格&库存,您可以联系我们找货
