RTV630-1P
RTV630-1P
    MGCHEMICALS
    POTTING COMPOUND HIGH STRENGTH
RTV630-1P 数据手册
RTV Silicones >> Blue, self leveling >> 2 part, Red, 2 Part Flowable Potting and Encapsulating Compound RTV Silicones by RTV Number... 2-Part Potting/Encapsulating Compound RTV630 Technical Support for RTV Silicones 1-800-255-8886 M.G. Chemicals Disclaimer for RTV Silicones > Jump to Product Number Product Number... Accessories Adhesives Brushes Cleaners / Degreasers Contact Cleaners Desoldering Braid Dusters & Circuit Coolers EMI / RFI Shielding Epoxies Primary Characteristics Self leveling Addition cure Cures in deep sections Very high strength Medium viscosity Primer required Use for: Encapsulating applications requiring high tensile strength Exceptionally deep potting applications Flux and Flux Remover Glass & Screen Cleaners Isopropyl Alcohol Lead Free Solder Lubricants Potting & Encapsulating Protective Coatings Will form thin, light-weight molds with excellent durability. The high tear resistance and inherent release ability make it well suited to the manufacture of intricate castings, by reproducing each part exactly to detail. Other applications include prototype parts, production tools for casting epoxies and rubber rolls. Electrical circuits require a tough potting compound with outstanding vibration withstanding capability find RTV630 unequalled. Silicone primeris required. Specialized Cleaners Swabs Thermal Management Thermally Conductive Adhesives Wipes MSDS Catalyst options/MSDS Primer options/MSDS Specifications Available Sizes RTV21 Available Sizes RTV31 Catalog Number Sizes Available Description RTV60 RTV630-1P 1 pint 1 lb kit RTV88 RTV630 requires a primer. Visit our primer guide for details. RTV560 RTV566 RTV577 Specifications RTV630 RTV Silicones Soldering/desoldering Quick Links Related products: Pens Prototyping Materials Locate Distributor > Use Adhesive Sealant Special Feature High tensile strength Cross Reference RTV630 RTV656 Uncured Properties Consistency Pourable Color Beige (part A) Blue (part B) Specific Gravity 1.28 Tack Free Time 4 hours Cure Through Time 7 days @ 25°C 15 min @ 150°C Useful Temp. Range -60°C to 204°C (-75°F to 400°F) Cured Properties - MECHANICAL Selection Guide One Part Chart Two Part Chart General Purpose Aerospace Marine High Performance Assembly Electronics Hardness 60 (Shore A) Tensile Strength 5.69 MPa (820 psi) Elongation 250% Tear Strength 20 kg/cm (110 lb/in) Thermal Conductivity High Temperature Low Temperature Cured Properties - ELECTRICAL Volume Resistivity 4.5 x 1015 ohm · cm Dielectric Strength 17.7 kV/mm (450 V/mil) Dielectric Constant 3.2 @ 1000 Hz Cured Properties - THERMAL http://www.mgchemicals.com/products/630.html (1 of 2)11/24/2008 8:06:45 AM Google Search MG RTV Silicones >> Blue, self leveling >> 2 part, Red, 2 Part Flowable Potting and Encapsulating Compound Thermal Conductivity 0.25 W/m · °K Brittle Point -60°C (-75°F) Thermal Expansion 21 x 10-5 (°C)-1 Other Viscosity (@ 25°C) 150,000 cps Mix Ratio (by weight) 10 : 1 Pot Life 4 hours Return to top ^ © 2000 - 2007 MG Chemicals. All rights reserved. Site Map Terms & Conditions Contact Us web site design by offbeat studio http://www.mgchemicals.com/products/630.html (2 of 2)11/24/2008 8:06:45 AM
RTV630-1P 价格&库存
很抱歉,暂时无法提供与“RTV630-1P”相匹配的价格&库存,您可以联系我们找货
