TSE397C-100G
TSE397C-100G
    MGCHEMICALS
    SIL
    ADHESIVE SEAL SIL NON-CORROSIVE
TSE397C-100G 数据手册
RTV Silicones >> Fast Cure Electronics grade >> translucent, 1 Part self leveling paste, RTV Silicone Adhesive Sealant RTV Silicones by Technical Support for RTV Silicones 1-Part Adhesive Sealant TSE397C RTV Number... Jump to Product Number Product Number... Accessories Adhesives Brushes 1-800-255-8886 Primary Characteristics Translucent Self leveling paste Fast cure Electronics application Non-corrosive Alkoxy neutral cure MIL-A-46146, group 1, type 1 UL HB recognition UL File No. E36952 Cleaners / Degreasers Excellent for thin section potting, filling small surface voids, self leveling, and protective coating. Non-corrosive (MIL-A46146A)* to electronic metals, including copper and brass. Excellent electrical insulating properties. Resistant to heat, cold, moisture, UV, and ozone. *Does not meet hydrolytic stability requirements of MIL-A-46146A. Contact Cleaners Desoldering Braid M.G. Chemicals Disclaimer for RTV Silicones > Locate Distributor > Quick Links MSDS Specifications Available Sizes Dusters & Circuit Coolers EMI / RFI Shielding Available Sizes Related products: Epoxies Flux and Flux Remover Catalog Number Sizes Available Description Glass & Screen Cleaners TSE397C-100G 100 g (3.5 oz) Tube Isopropyl Alcohol TSE397C-333ML 333mL (10 oz) Cartridge Lead Free Solder RTV160 White RTV162 White RTV167 Gray TSE399C Clear Lubricants Potting & Encapsulating Specifications Protective Coatings Pens Use Adhesive Sealant Prototyping Materials Special Feature Clear Semi Flowable Standards MIL-A-46146-A Cross Reference TSE397 RTV Silicones Soldering/desoldering Specialized Cleaners Swabs Thermal Management Thermally Conductive Adhesives Wipes Uncured Properties Selection Guide One Part Chart Two Part Chart General Purpose Consistency Self Leveling Aerospace Color Translucent Marine Specific Gravity 1.04 High Performance Assembly Tack Free Time 10 min Electronics Cure Through Time 72 hours Thermal Conductivity Useful Temp. Range -55°C to 200°C (-67°F to 392°F) High Temperature Cured Properties - MECHANICAL Hardness 20 Shore A Tensile Strength 1.1 MPa (156 psi) Elongation 300% Low Temperature Cured Properties - ELECTRICAL Volume Resistivity 2.0 x 1015 ohm · cm Dielectric Strength 20 kV/mm 510 V/mil Dielectric Constant 2.9 @ 60 Hz Cured Properties - THERMAL Thermal Conductivity 0.21 W/m · °K Thermal Expansion 27 x 10-5 (°C)-1 Other http://www.mgchemicals.com/products/397.html (1 of 2)11/24/2008 8:36:36 AM Google Search MG RTV Silicones >> Fast Cure Electronics grade >> translucent, 1 Part self leveling paste, RTV Silicone Adhesive Sealant Viscosity (@ 25°C) Return to top ^ © 2000 - 2007 MG Chemicals. All rights reserved. Site Map Terms & Conditions Contact Us web site design by offbeat studio http://www.mgchemicals.com/products/397.html (2 of 2)11/24/2008 8:36:36 AM 50,000 cps
TSE397C-100G 价格&库存
很抱歉,暂时无法提供与“TSE397C-100G”相匹配的价格&库存,您可以联系我们找货
