E07-314CB-1M
E07-314CB-1M
    MICROCONNECTORS
    CABLE B PLUG TO C PLUG 3.3
E07-314CB-1M 数据手册
1 Meter USB TYPE-C to USB 2.0 TYPE-B E07-314CB-1M Product Overview This USB 2.0 USB-C to USB-B cable is the perfect solution for connecting a printer, hub, or other device that has a USB B port to a computer, tablet or other device that has a USB Type-C port for USB 2.0 communication. The color coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. The USB Type-C connector is smaller than traditional USB connector and features a symmetrical design which allows it to be easily connected on the first try. Additionally, the durability of the USB Type-C connector allows for up to 10,000 connection cycles. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging. Note: This cable is designed to support USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 Communication and features.
E07-314CB-1M 价格&库存
很抱歉,暂时无法提供与“E07-314CB-1M”相匹配的价格&库存,您可以联系我们找货
