E08-025B-SLIM
E08-025B-SLIM
    MICROCONNECTORS
    25 Slim CAT6 28AWG UTP Black
E08-025B-SLIM 数据手册
25ft Ultra Slim 28AWG UTP CAT6 Patch Cable (Black) (E08-025B-SLIM) Product Overview Micro Connectors CAT 6A Ultra Slim Patch Cable is a high performance, compact, low-profile ethernet cable with a slim diameter designed to fit in tight spaces. Up to 60% thinner than standard CAT 6A cable, this flexible cable is space-saving and improves airflow in data centers and telecommunication rooms. Features: Ultra slim design and up to 60% thinner than standard cable         Low-profile and compact to cut down clutter in tight network environment OD = 3.6mm High performance CAT 6A 10-Gigabit ethernet standard and backwards compatible with CAT 6 Improves airflow and cable management by reducing clutter in tight spaces Gold-plated 50-micron contacts ensure clear transmission by eliminating signal loss 28 AWG wire and made with 100% bare copper Compliant with major EIA/TIA, UL, ETL, and RoHS standards Available Lengths: 100, 50, 25, 14, 7, 3, 1 ft
E08-025B-SLIM
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款具有锁存功能的六进制计数器/分频器,广泛应用于数字电路中。
3. 引脚分配:引脚1为Vcc,引脚2为Q0,引脚3为Q1,引脚4为Q2,引脚5为Q3,引脚6为Q4,引脚7为Q5,引脚8为GND。
4. 参数特性:工作电压范围为3-18V,工作频率可达100MHz。
5. 功能详解:EL817内部包含6个D触发器,可实现六进制计数功能。
6. 应用信息:常用于数字钟表、频率分频等场合。
7. 封装信息:采用DIP16封装。
E08-025B-SLIM 价格&库存
很抱歉,暂时无法提供与“E08-025B-SLIM”相匹配的价格&库存,您可以联系我们找货
