E11-007BL
E11-007BL
    MICROCONNECTORS
    7 CAT7 SFTP Shielded RJ45 26AWG
E11-007BL 数据手册
7ft CAT7 SFTP Double Shielded RJ45 Snagless Ethernet 26AWG Cable (Blue) (E11-007BL) Product Overview Micro Connectors Cat-7 Ethernet patch 26AWG cable is designed for superior performance in applications utilizing 10 Gigabit Ethernet. With a 600MHz bandwidth and speeds of up to 10Gbps, the Cat-7 cable is perfect for use in datacenters, server rooms, telecommunications rooms, and large enterprise networks. Our cable features a compact snagless boot design, with strain relief for durability. It also features two shielded RJ45 connectors on each end, each with 50u” gold-plated contacts for maximum corrosion resistance for the most reliable connections. Along with a double shielding (S/FTP), our cable allows for maximum performance while minimizing electromagnetic interference/radio-frequency interference (EMI/RFI) and almost eliminating alien crosstalk (AXT). Made from a flexible PVC material and with lengths from 1 foot to 100 feet, our CAT 7 Ethernet patch cable is your best companion for demanding, high-bandwidth environments. Features: ● 600MHZ rated speed ● 10 Gbps data transfer rates ● Backwards compatible with all CAT-5, CAT-5e, CAT-6, and CAT-6a applications ● Shielded (S/FTP) 26AWG cable: individual twisted pairs shielded with Aluminum Mylar foil, then bundled together with an 85% tinned copper braid shield to minimize EMI, RFI, and AXT ● 50u” gold plated contacts for accurate data transfer and maximum corrosion resistance ● Snagless boots for simplified moves, adds, and changes ● Available in lengths: 1ft, 3ft, 7ft, 10ft, 14ft, 25ft, 50ft, 100ft
E11-007BL 价格&库存
很抱歉,暂时无法提供与“E11-007BL”相匹配的价格&库存,您可以联系我们找货
