E11-025FL-W
E11-025FL-W
    MICROCONNECTORS
    25 CAT7 SFTP Flat RJ45 26AWG
E11-025FL-W 数据手册
25ft CAT7 Shielded RJ45 Flat Patch Cable with 32AWG Cable Clips (White) (E11-025FL-W) Product Overview The Micro Connectors Cat7 Ethernet patch 32AWG cable is designed for superior performance in applications utilizing 10 Gigabit Ethernet. With a 600MHz bandwidth and speeds of up to 10Gbps, the Cat-7 cable is perfect for use in data centers, server rooms, telecommunications rooms, and large enterprise networks. Micro Connectors flat high performance gigabit Ethernet patch cables are perfect for connecting your PC to a network in areas where space is tight. With all the reliability and performance of a standard Cat7 patch cable, this 1.2mm thick cable is able to fit into even the tightest space and give a neater, less cluttered appearance to your desktop or wall jacks. Features: • With all the reliability and performance of a standard Cat7 patch cable, this 1.2mm thick cable is able to fit into even the tightest space • Perfect for connecting your PC to a network in areas where space is tight • Shielded (S/FTP) cable: individual twisted pairs shielded with Aluminum Mylar foil, then bundled together with an 85% tinned copper braid shield to minimize EMI, RFI, and AXT • Designed specifically for Gigabit Ethernet applications • RJ45 plug features gold connectors to prevent corrosion thus ensuring a longer cable life • Comes with 10 cable clips
E11-025FL-W 价格&库存
很抱歉,暂时无法提供与“E11-025FL-W”相匹配的价格&库存,您可以联系我们找货
