F04-01ARGB-50
F04-01ARGB-50
    MICROCONNECTORS
    50cm ARGB Ext Cable w/2 Male Pin
F04-01ARGB-50 数据手册
50cm Addressable RGB Extension Cable with/2 Male Pins F04-01ARGB-50 50cm Addressable RGB Extension Cable The Micro Connectors Addressable RGB cable is the perfect accessory which allows users to extend and connect their addressable RGB LED lighting strips or fans through a single motherboard 3-pin ARGB header. Made from a flexible PVC material and with lengths from 30 to 50cm, and with the added bonus of male pins included in each package, this RGB extension cable is your best companion for your Addressable RGB lighting needs. Features: Males pins included for convenience Flexible PVC material for easy routing in tight spaces Lengths range from 30 to 50cm Specifications: Cable Material: PVC Pin Material: Brass Length: 50 Centimeters Weight: 0.10 lbs Package Contents: ARGB extension cable & 2 male pins
F04-01ARGB-50 价格&库存
很抱歉,暂时无法提供与“F04-01ARGB-50”相匹配的价格&库存,您可以联系我们找货
