F04-04ARGB-30
F04-04ARGB-30
    MICROCONNECTORS
    30cm ARGB 1-4 Splitter Cable
F04-04ARGB-30 数据手册
30cm Addressable RGB 1 to 4 Splitter Cable with/5 Male Pins F04-04ARGB-30 30cm Addressable RGB 1 to 4 Splitter Cable The Micro Connectors Addressable RGB 1 to 4 splitter cable is the perfect accessory which allows users to extend and connect their addressable RGB LED lighting strips or fans through a single motherboard 3-pin ARGB header. Made from a flexible PVC material and with lengths from 30 to 50cm, and with the added bonus of male pins included in each package, this RGB splitter cable is your best companion for your Addressable RGB lighting needs. Features: Males pins included for convenience Flexible PVC material for easy routing in tight spaces Lengths range from 30 to 50cm Specifications: Model: F04-04ARGB-30 Cable Material: PVC Pin Material: Brass Color: Black Length: 30 centimeters Weight: 0.10 lbs Package Contents: ARGB splitter cable & 5 male pins
F04-04ARGB-30 价格&库存
很抱歉,暂时无法提供与“F04-04ARGB-30”相匹配的价格&库存,您可以联系我们找货
