F04-15AS70-BK
F04-15AS70-BK
    MICROCONNECTORS
    70cm 3Pin 1-5 ARGB Split Cable
F04-15AS70-BK 数据手册
Premium Sleeved 3-Pin 1 to 5 Addressable (ARGB) Splitter Cable – 70cm Black F04-15AS70-BK Premium Sleeved 3-Pin 1 to 5 Addressable (ARGB) Splitter Cable – 70cm Black The Micro Connectors Addressable RGB 1 to 5 splitter cable is the perfect accessory which allows users to extend and connect their addressable RGB LED lighting strips or fans through a single motherboard 3-pin ARGB header. Made from a longer 70cm flexible premium weave sleeving, and with the added bonus of male pins included in each package, this RGB splitter cable is your best companion for your Addressable RGB lighting needs. Features: Premium weave sleeving and longer length Males included for convenience Flexible PVC material for easy routing in tight spaces Compatible with 3-Pin ARGB LED fans and lights Specifications: Pin Material: Brass Color: Black Length: 70 cm Package Contents: ARGB splitter cable, male pins
F04-15AS70-BK 价格&库存
很抱歉,暂时无法提供与“F04-15AS70-BK”相匹配的价格&库存,您可以联系我们找货
