F04-RGB03-50
F04-RGB03-50
    MICROCONNECTORS
    50cm 1-3 RGB Splitter Cable
F04-RGB03-50 数据手册
50cm 1 to 3 RGB Splitter Cable with 4 Male Pins F04-RGB03-50 50cm 1-to-3 RGB Splitter Cable The Micro Connectors 1-to-3 RGB splitter cable is the perfect accessory which allows users to extend and connect multiple RGB LED lighting strips or fans between RGB controllers, RGB capable motherboards or just extending space between your RGBs enabling you to install it in your preferred locations. Made from a flexible PVC material and with lengths from 30 to 50cm, this 4-pin 1-to-3 RGB splitter cable is both compatible with 4 or 5-pin RGB headers allowing broad compatibility. With the added bonus of male pins included in each package, this RGB splitter cable is your best companion for your RGB lighting needs. Features: • Compatible with 5050/3528 4-pin RGB LED strip lights • Compatible with 4-pin RGB LED fans • Connects up to 3 RGB lights or fans to a single source • Works with 4-pin RGB or 5-pin RGBW header • Males pins included for convenience • Flexible PVC material for easy routing in tight spaces • Lengths range from 30 to 50cm Specifications/Contents: Cable material: PVC Pin material: Brass Length: 50 centimeters Weight: 0.1 lbs Connector: 4-pin female (12V, G, R, B) Connector withstanding voltage: 300V Pin rated current: 3A Package contents: RGB splitter cable, 4 male pins
F04-RGB03-50
物料型号: 50cm 1-to-3 RGB Splitter Cable with 4 Male Pins F04-RGB03-50
器件简介: Micro Connectors 1-to-3 RGB splitter cable,用于扩展和连接多个RGB LED灯带或风扇,可与RGB控制器、RGB主板或仅用于扩展RGB设备之间的空间。由柔性PVC材料制成,长度范围从30到50cm,兼容4针或5针RGB接口。
引脚分配: 4-pin female (12V, G, R, B),即4针母头,分别对应12V、绿色(G)、红色(R)、蓝色(B)。
参数特性: - 兼容5050/3528 4-pin RGB LED灯带 - 兼容4-pin RGB LED风扇 - 可连接至3个RGB灯或风扇至单一源头 - 适用于4针RGB或5针RGBW接口 - 包装内含4个公针,方便使用 - 柔性PVC材料,便于在狭窄空间中布线 - 长度为50厘米,重量为0.1磅 - 连接器耐压300V,针额定电流3A
功能详解: 该RGB分线器电缆允许用户将RGB LED灯带或风扇扩展并连接到RGB控制器、支持RGB的主板或简单地扩展RGB设备之间的空间,以便于在用户偏好的位置安装。
应用信息: 适用于需要扩展RGB设备连接的场景,如PC装机、LED照明等。
封装信息: Micro Connectors, Inc. 位于加利福尼亚州海沃德,提供RGB分线器电缆和4个公针。
F04-RGB03-50 价格&库存
很抱歉,暂时无法提供与“F04-RGB03-50”相匹配的价格&库存,您可以联系我们找货
