F04-RGB04-30
F04-RGB04-30
    MICROCONNECTORS
    30cm 1-4 RGB Splitter Cable
F04-RGB04-30 数据手册
30cm 1 to 4 RGB Splitter Cable with 5 Male Pins F04-RGB04-30 The Micro Connectors 1-to-4 RGB splitter cable is the perfect accessory which allows users to extend and connect multiple RGB LED lighting strips or fans between RGB controllers, RGB capable motherboards or just extending space between your RGBs enabling you to install it in your preferred locations. Made from a flexible PVC material and with lengths from 30 to 50cm, this 4-pin 1-to-4 RGB splitter cable is both compatible with 4 or 5-pin RGB headers allowing broad compatibility. With the added bonus of male pins included in each package, this RGB splitter cable is your best companion for your RGB lighting needs. Features: • Compatible with 5050/3528 4-pin RGB LED strip lights • Compatible with 4-pin RGB LED fans • Connects up to 4 RGB lights or fans to a single source • Works with 4-pin RGB or 5-pin RGBW header • Males pins included for convenience • Flexible PVC material for easy routing in tight spaces Specifications/Contents: Cable material: PVC Pin material: Brass Length: 30 Centimeters (11.82 in) Connector: 4-pin female (12V, G, R, B) Connector withstanding voltage: 300V Pin rated current: 3A Package contents: RGB splitter cable, 5 male pins
F04-RGB04-30 价格&库存
很抱歉,暂时无法提供与“F04-RGB04-30”相匹配的价格&库存,您可以联系我们找货
