FBR-1012-3M
FBR-1012-3M
    MICROCONNECTORS
    Fiber Optic 10G OM3 LC-SC 3M
FBR-1012-3M 数据手册
3 Meter LC/SC 10Gb Multimode OM3 Duplex 50/125 Fiber Optic Cable (FBR-1012-3M) Product Overview OM3 LC TO SC 10GB MULTI-MODE FIBER OPTIC CABLE        Our high quality OM3 multi-mode fiber cable with LC/SC connectors is perfect for high-throughput applications. Support 10Gb up to 300 meters, 40Gb and 100Gb up to 100 meters. With an Effective Modal Bandwidth (EMB) of 2000 MHz/km at 850nm. OFNR (riser) rated fiber cable is ideal for use in upright shafts that run between floors in the building. The small LC connector is perfect for high density network applications. Use with LED and VCSEL laser light sources. Backward compatible with LED-based 50/125 multimode fiber applications. Polish Type: UPC to UPC Insertion Loss: < 0.3 dB Return Loss: > 35 dB Jacket OD: 2.0 mm
FBR-1012-3M 价格&库存
很抱歉,暂时无法提供与“FBR-1012-3M”相匹配的价格&库存,您可以联系我们找货
