NGFFM2-HS-KIT
NGFFM2-HS-KIT
    MICROCONNECTORS
    M.2 NVME KIT LOW-PROF HS & SCREW
NGFFM2-HS-KIT 数据手册
M.2 NVME SSD Installation Kit with Low-Profile Heat Sink and Mounting Screws (NGFFM2-HS-KIT) Features: • M.2 SSD mounting screws • Hex Head Jackscrews • Thumb Screws Standoffs • Flat Head Screws • Transparent Screw Washers • Screwdriver • Supports 2280 length M.2 SSD • Low-profile to work around tight spaces • Aluminum alloy fins for optimal heat dissipation • Works on motherboards or M.2 Adapters • Easy installation with thermal pad • Silicone rings included to secure heat sinks Specifications/Contents: • Model: NGFFM2-HS-KIT • M.2 SSD Size Support: 2280 (22 x 80mm) • Material: Aluminum, silicone • Color: Black • Contents: High Jackscrews x 2, Low Jackscrews x 2, High Thumb Screws Standoffs x 2, Low Thumb Screw Standoffs x 2, Flat Head Screws x 4, Washers x 4, Screwdriver, Heat sink, Thermal pad, Silicone rings, QiG
NGFFM2-HS-KIT 价格&库存
很抱歉,暂时无法提供与“NGFFM2-HS-KIT”相匹配的价格&库存,您可以联系我们找货
