NGFFM2-HSDS-BK
NGFFM2-HSDS-BK
    MICROCONNECTORS
    Double-Sided Alum M.2 SSD HS Kit
NGFFM2-HSDS-BK 数据手册
M.2 SSD Double-Sided Aluminum Heat Sink Kit (NGFFM2-HSDS-BK) Features:          Supports 2280 Length M.2 SSD Low-Profile and Compact Design to Work Around Tight Spaces Adjustable Height Design for Both Single and Double-Sided M.2 SSDs Compatible with PS5 M.2 SSD Storage Expansion and PC Total Height of 10.5mm w/M.2 SSD Installed to fit in Tight Spaces Cross-Cut Aluminum Alloy Heat Sink for Optimal Heat Dissipation Quality Thermal Pads Included for Efficient Heat Transfer Adjustable Screw Installation with Base Plate for Secure Fit Lowers Temperature from up to 15 to 30 Degrees Celsius preventing overheating SSD from throttling Specifications/Contents: Model: NGFFM2-HSDS-BK M.2 SSD Size: 2280 (22 x 80mm) Material: Aluminum Color: Black Box contents: M.2 Heat Sink, Thermal Pads, Screws, Screwdriver, QIG Heat Sink Dimensions: 77 x 23.2 x 10.5mm
NGFFM2-HSDS-BK 价格&库存
很抱歉,暂时无法提供与“NGFFM2-HSDS-BK”相匹配的价格&库存,您可以联系我们找货
