PCIE-M20802HS
PCIE-M20802HS
    MICROCONNECTORS
    M.2 NVME/M.2 SATA SSD PCIE X4
PCIE-M20802HS 数据手册
M.2 NVMe + M.2 SATA 80mm SSD PCIe x4 Adapter with Heat Sink (PCIE-M20802HS) Features: • Heat sink kit to prevent overheating • Supports two M.2 SSDs simultaneously • Compatible with M.2 SSD up to 80mm length • Converts one M.2 (M key) SSD to PCIe x4 interface • Converts a second M.2 (B key) into SATA interface • Gold-clad surface mounting to conduct and dissipate heat • Low-profile bracket included Specifications/Contents: Model: PCIE-M20802HS Interface: PCIe x4 and SATA III M.2 SSD Key: NVMe or AHCI (M Key); SATA III (B Key) Number of Drives: 2 M.2 SSD Size: 30mm, 42mm, 60mm, 80mm OS support: Windows 7/8/8.1/10, Mac OS 10.2.8 or above, Linux Box contents: PCIe x4 adapter, high and low-profile bracket, heat sink, thermal pad x3, mounting screws
PCIE-M20802HS 价格&库存
很抱歉,暂时无法提供与“PCIE-M20802HS”相匹配的价格&库存,您可以联系我们找货
