RAS-PCS04PWR-RD
RAS-PCS04PWR-RD
    MICROCONNECTORS
    ALUM RASPPI 3 CASE MODEL B/B+ W/
RAS-PCS04PWR-RD 数据手册
Aluminum Raspberry Pi 3 Case for Model B/B+ with Fan, Heatsinks, and UL Approved On/Off Power Adapter (RAS-PCS04PWR-RD, RAS-PCS04PWR-SL, RAS-PCS04PWR-BK, RAS-PCS04PWR-BL) Micro Connectors’ Aluminum Raspberry Pi 3 Case for Model B/B+ is a highquality durable aluminum case that’s designed to help to deal with the high temperatures of your Pi and dissipate its heat. The precision-cut casing allows easy access to all ports. Our kit also comes with heatsinks and an active cooling fan to actively draw out heat from your Pi as well as a UL approved power supply with an easy-to-use on/off switch—all the essentials to get keep your Pi project started today! FEATURES • • • Compatible with: o Raspberry Pi 1 Model B+ o Raspberry Pi 2 Model B o Raspberry Pi 3 Model B/B+ Wall-mount compatible 40mm low noise cooling fan with one-to-two wire connector pins (3.3V or 5V) to provide optimal fan speed and air flow INCLUDES • • Aluminum case Micro USB power adapter • • • • • • 47in/3.9ft Micro USB power adapter is: o UL and FCC approved o DoE Level VI efficiency o Over voltage and short circuit protection o Input: AC100-240V/5060Hz o Output: DC 5V/2.5A Comes in red, silver, black, and blue Cooling fan (2) Heatsinks Anti-slip rubber feet pads Screws and screwdriver
RAS-PCS04PWR-RD 价格&库存
很抱歉,暂时无法提供与“RAS-PCS04PWR-RD”相匹配的价格&库存,您可以联系我们找货
