RAS-PCS04-SL
RAS-PCS04-SL
    MICROCONNECTORS
    ALUM RASP PI 3 MODEL B/B+ CASE W
RAS-PCS04-SL 数据手册
Aluminum Raspberry Pi 3 Model B/B+ Case with Fan (RAS-PCS04-RD, RAS-PCS04-SL, RAS-PCS04-BK, RAS-PCS04-BL) Micro Connectors’ Aluminum Raspberry Pi 3 Case for Model B/B+ is a highquality durable aluminum case that’s designed to help to deal with the high temperatures of your Pi and dissipate its heat. The precision-cut casing allows easy access to all ports. Our kit also comes with heatsinks and an active cooling fan to actively draw out heat from your Pi—all the essentials to get keep your Pi project cool! FEATURES • • • • Compatible with: o Raspberry Pi 1 Model B+ o Raspberry Pi 2 Model B o Raspberry Pi 3 Model B/B+ Wall-mount compatible 40mm low noise cooling fan with one-to-two wire connector pins (3.3V or 5V) to provide optimal fan speed and air flow Comes in red, silver, black, and blue INCLUDES • • • • • Aluminum case (2) Heatsinks Cooling fan Anti-slip rubber feet pads Screws and screwdriver
RAS-PCS04-SL 价格&库存
很抱歉,暂时无法提供与“RAS-PCS04-SL”相匹配的价格&库存,您可以联系我们找货
