TR4-570SH-BL
TR4-570SH-BL
    MICROCONNECTORS
    1000 CAT 6A Solid Shield 23AWG
TR4-570SH-BL 数据手册
1000ft Cat6A Solid STP Bulk Ethernet 23AWG Cable (Blue) TR4-570SH-BL Micro Connectors' Bulk CAT6A Shielded Cable comes conveniently packaged in a pull box, providing you with 1000 feet of high quality, shielded, 4-pair, solid, 500 MHz Cat6A Cable, ready for termination and routing. The Mylar foil shielding protects your data as it travels through the four twisted pairs of 23 gauge solid copper wires by wrapping it in a thin metal sleeve thus keeping electrical interference from things like fluorescent lights and electrical lines found in a drop ceiling or inside walls at a minimum. Simply pull the length required for your installation straight from the box and terminate at your leisure. These boxes are a great aid in large scale network installations and other long distance cable runs. And like all of our bulk networking cables, these are constructed with only high-quality components that can be counted on for high performance. Features: • Shielded cables designed to prevent EMI Interference and ensuring best signal possible • 23AWG (American wire gauge) individual solid pure copper conductors for permanent installation • Full 10 Gigabit network speed at 500 MHz performance • Ideal for PoE and VoIP applications where data loss is audibly and visually seen and heard • Meets ANSI/TIA-568-C specifications • Comes on a convenient spool inside a pull box for easy access • RoHS compliant
TR4-570SH-BL 价格&库存
很抱歉,暂时无法提供与“TR4-570SH-BL”相匹配的价格&库存,您可以联系我们找货
