250 FT CAT6 Shielded (F/UTP) 23 AWG Solid Copper Bulk
Ethernet Cable with 10-Pack Universal Shielded RJ45
Connectors - Blue
(TR4-60SHBL250-K)
Micro Connectors' Bulk CAT6 Shielded Cable comes on a convenient wooden spool for easy
access, providing you with 250 feet of high quality, solid full copper wire with overall
aluminum foil shielding, ready for termination and routing. The Mylar foil shielding protects
your data as it travels through the four twisted pairs of 23-gauge solid copper wires by
wrapping it in a thin metal sleeve thus keeping electrical interference from things like
fluorescent lights and electrical lines found in a drop ceiling or inside walls at a minimum.
Simply pull the length required for your installation straight from the spool and terminate at
your leisure. These cables are a great aid in large scale network installations and other longdistance cable runs and like all of our bulk networking cables, these are constructed with only
high-quality components that can be counted on for high performance.
Features:
Overall aluminum foil shielding (F/UTP) In-Wall Rated Category 6 Ethernet cable
23 AWG individual solid pure copper conductors
Supports Power over Ethernet: PoE, PoE+, and PoE++
Bandwidth speed up to 550 MHz
Cross separator spline to ensure better signal performance and less crosstalk
Comes on a convenient wooden spool for easy access
Running “FT” count printed on cable for easy measurement
Meets ANSI/TIA-568-C specifications and UL, RoHS and TAA compliant
Each package comes with 10 sets of shielded modular connectors
*Due to the overall thickness of the shielded bulk cable, some standard RJ45 connectors will
not fit properly with this cable. We recommend using our universal CAT 7/6A/6 shielded
modular connectors (C20-088L7S-20) or purchase the bundle kit to ensure a correct
installation for optimal signal performance*
Specifications/Contents:
Model: TR4-60SHBL250-K
Category: CAT 6
Conductor: Solid bare copper
Wire Gauge: 23 AWG
Cable Jacket: CM In-wall rated
Shielding: F/UTP overall aluminum foil shielding
Color: Blue
Length: 250 ft
Overall Cable Outer Diameter: 6.9 mm
Package Includes: 250 ft CAT 6 cable and 10 pcs of shielded connectors
Weight: 9 lbs
很抱歉,暂时无法提供与“TR4-60SHBL250-K”相匹配的价格&库存,您可以联系我们找货
