250Ft CAT 6A Solid & Shielded (F/UTP) Bulk Ethernet Cable
with 10-Pack Universal Shielded RJ45 Connectors - Blue
(TR4-70SHBL250-K)
Micro Connectors' Bulk CAT6A Shielded Cable comes on a convenient wooden
spool for easy access, providing you with 250 feet of high quality, solid full
copper wire with overall aluminum foil shielding, ready for termination and
routing. The Mylar foil shielding protects your data as it travels through the four
twisted pairs of 23-gauge solid copper wires by wrapping it in a thin metal
sleeve thus keeping electrical interference from things like fluorescent lights
and electrical lines found in a drop ceiling or inside walls at a minimum. Simply
pull the length required for your installation straight from the spool and
terminate at your leisure. These cables are a great aid in large scale network
installations and other long-distance cable runs and like all of our bulk
networking cables, these are constructed with only high-quality components
that can be counted on for high performance.
Features:
Overall aluminum foil shielding (F/UTP) CM In-Wall Rated Category 6A
Ethernet cable
23 AWG individual solid pure copper conductors
Supports Power over Ethernet: PoE, PoE+, and PoE++
CAT6A speeds up to 10Gbps and 550 MHz bandwidth
Cross separator spline to ensure better signal performance and less
crosstalk
Comes on a convenient wooden spool for easy access
Running “FT” count printed on cable for easy measurement
Meets ANSI/TIA-568-C specifications and UL, RoHS and TAA compliant
Each package comes with 10 sets of shielded modular connectors
*Due to the overall thickness of the shielded bulk cable, some standard RJ45
connectors will not fit properly with this cable. We recommend using our
universal CAT 7/6A/6 shielded modular connectors (C20-088L7S-20) or purchase
the bundle kit to ensure a correct termination for optimal signal performance*
Specifications/Contents:
Model: TR4-70SHBL250-K
Category: CAT 6A
Conductor: Solid bare copper
Wire Gauge: 23 AWG
Cable Jacket: CM In-wall rated
Shielding: F/UTP overall aluminum foil shielding
Color: Blue
Length: 250 ft
Overall Cable Outer Diameter: 7.0 mm
Package Includes: 250 ft CAT 6A cable and 10 shielded connectors
Weight: 12 lbs
很抱歉,暂时无法提供与“TR4-70SHBL250-K”相匹配的价格&库存,您可以联系我们找货
