MM120-001650
MM120-001650
    MICRO-MEASUREMENTS
    Strain Gauge Welder Strain Gauges
MM120-001650 数据手册
Model 700B Portable Strain Gage Welding Unit FEATURES • Lightweight and compact size. • Weld energy is continuously adjustable from 10 to 60 joules, making the Model 700B an excellent choice for installing weldable strain gages and temperature sensors, as well as small thermocouples and light-gage metal. • Fast welding rate – up to 60 welds per minute • Replaceable rechargeable battery allows smooth continuous operation. • “Low-battery” indication to warn the user when the Li-ion battery requires charging. • Optional carrying bag with shoulder strap and belt loops providing convenient storage space for cables, batteries, battery charger welding tips and instruction manual • Optional ruggedized work case for safe storage of kit DESCRIPTION The Model 700B is an update to our Model 700 welding and soldering unit which has been used for decades for installing many thousands of strain gages worldwide. It offers a modern, compact design with a removable Lithium-ion battery and has a rugged exterior for use in adverse field conditions. This lighter unit (less than a third of the previous design) and compact dimensions simplifies installations in difficult-to-reach environments. An optional ballistic nylon bag with straps and a carabiner is available with additional space for storing accessories. Weld energy can be changed from 10 to 60 joules in 1 joule increments, indicated on a digital display. It is capable of producing 60 welds/minute for fast installation. Approximately 1500 welds can be performed on a single charge, equivalent to around 30 Micro-Measurements linear weldable gages. A removable battery pack and a 30-minute fast charger enables continuous working. Successful and consistent welds require a proper earth connection; both mechanical clamp and magnetic mount earth leads are available. For additional safety and improved performance a resistance-to-ground check is performed for every weld. The Micro-Measurements Model 700 Welder is ideal for installing Micro-Measurements CEA, LWK, LEA, LZN and LZE weldable strain gages. Proper installation techniques for weldable gages are detailed in our Instruction Bulletin B-131. SPECIFICATIONS All specifications are nominal or typical at +73°F (+23°C) unless noted. PARAMETER SPECIFICATION GENERAL Power for recharging 115 VAC or 230 VAC, 50-60 Hz. (different chargers) Temperature range Operating and storage Battery storage -4°F to +140°F (–20°C to +60°C) +40°F to +105°F (+4°C to +40°C) (recommended) Size Main unit Handle Battery Cables (2) 8.25 x 7.5 x 3 in (210 x 191 x 76.2 mm) 6.25 x 1.85 x 3.3 in (159 x 47 x 84 mm) 1.9 x 1.2 x 3.4 in (48 x 30 x 86 mm) 60 x 0.31 in (1524 x 7.9 mm) Weight 6.9 lb (3.14 kg) Main unit material Rugged powder-coated extruded aluminium, splash proof WELDING SPECIFICATIONS Weld Energy Range 10 to 60 joules, in 1-joule steps, adjustable by front-panel control. Maximum Weld Repetition Rate 60 per minute at 30 joules, typical 14141-EN Rev 26-Jan-2021 For technical questions, contact mm@vpgsensors.com www.micro-measurements.com 1 Model 700B Portable Strain Gage Welding Unit PARAMETER SPECIFICATION Number Of Welds Per Battery Charge Approximately 1500 at weld energy setting of 30 joules. This is equivalent to approx. 30 Micro-Measurements linear weldable gage installations Battery charge time (from full discharge): 40 minutes typical Battery Replaceable rechargeable Li-ion battery, 3.0 Ah, 7.6 – 12.6 Vdc (10.8Vdc nominal) Welding Probe Manually fired with trigger control and “steady-rest” Welding Cables Two 5 ft (1.5 m), fully flexible Ground cable Magnetic mount & mechanical clamp options, 5 ft (1.5 m), 6AWG Weld Energy Monitor Calibrated front-panel control with READY indicator; audible indication selectable SAFETY Auto detect ground
MM120-001650 价格&库存
很抱歉,暂时无法提供与“MM120-001650”相匹配的价格&库存,您可以联系我们找货
