MMF404066
MMF404066
    MICRO-MEASUREMENTS
    C5K-13-S5198-350-39F
MMF404066 数据手册
S5198 General Purpose Strain Gages—Rectangular Rosette GAGE PATTERN DATA – BASED ON ADVANCED SENSORS TECHNOLOGY GAGE DESIGNATION RESISTANCE (OHMS) OPTIONS AVAILABLE See Note 1 350 ± 0.5% 350 ± 0.5% C5K-XX-S5198-350/33F C5K-XX-S5198-350/39F DESCRIPTION Planar, 0°-45°-90° rosette for use in applications involving limited gaging areas or steep strain gradients. actual size GAGE DIMENSIONS Gage Length 0.014 ES 0.36 ES Overall Length 0.071 CP 1.81 CP Legend ES = Each Section S = Section (S1 = Section 1) Grid Width 0.012 ES 0.30 ES CP = Complete Pattern M = Matrix Overall Width 0.143 CP 3.63 CP Matrix Length 0.08 2.2 inch millimeter Matrix Width 0.15 3.9 GAGE SERIES DATA — See Gage Series datasheet for complete specifications Series Description Strain Range Temperature Range C5K Encapsulated Karma gages with pre-attached high-performance Teflon®-insulated thin, flexible cables, each consisting of 3 twisted wires. One cable per gage grid. Length selections: 33F = 3 cables, 3 ft long; 39F = 3 cables, 9 ft long. ±1.5% –100° to +400°F (–75° to +205°C); in short-term, exposure limit is +500°F (+260°C) Note 1: Insert desired S-T-C number in spaces marked XX. Teflon is a Registered Trademark of DuPont. Document No.: 11138 Revision: 13-Apr-2018 For technical questions, contact mm@vpgsensors.com www.micro-measurements.com 1
MMF404066 价格&库存
很抱歉,暂时无法提供与“MMF404066”相匹配的价格&库存,您可以联系我们找货
