MC21605DA6W-SPTLY-V2
    MIDAS
    2X16 CHARACTER CHIP-ON-BOARD LCD
MC21605DA6W-SPTLY-V2 数据手册
Electra House, 32 Southtown Road Great Yarmouth, Norfolk NR31 0DU, England MC21605DA6W-SPTLY-V2 2 x 16 5mm Character Height Specification Version: Telephone +44 (0)1493 602602 Fax +44 (0)1493 665111 Email:sales@midasdisplays.com www.midasdisplays.com LCD Module Date: 20/10/2016 1 Revision Display Features Character Count 2 x 16 Appearance Black on Yellow/Green Logic Voltage 5V Interface Parallel Font Set English / Japanese Transflective Display Mode 5.23mm Character Height LC Type STN Module Size 85.00 x 29.50 x 13.50 mm Operating Temperature -20°C ~ +70°C Construction COB Yellow/Green LED Backlight Box Quantity 45 pcs Weight / Display 28.88 grams * - For full design functionality, please use this specification in conjunction with the ST7066U specification. (Provided Separately) Display Accessories Part Number MCCMDB-16DIL MCCBL1A16DLIP -16DILS-150 Description LCD Interconnect board, can be driven from either a PC or a single Board computer with a USB output. 16 Way, Dual in-line to Dual In-line connector Cable. Optional Variants Fonts Appearances Black on White White on Blue Voltage Mechanical Specifications 85.00 x 29.50 x 13.5 ( With Backlight) Module Size W x H x D mm Viewing Area 64.50 x 16.40 W x H mm Hole-to-Hole 81.00 x 24.00 W x H mm Character Size Dot Size 3.00 x 5.23 0.56 x 0.61 W x H mm W x H mm Character Pitch Dot Pitch 0.51 x 0.52 0.05 x 0.05 W x H mm W x H mm MC21605DA6W-SPTLY-V2 2 x 16 5mm Character Height Specification Version: 1 Revision Date: 20/10/2016 LCD Module Pin Layout PI 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 SYMBOL Vdd(LED+) Vss(LED-) V0 RS R/W E DB0 DB1 DB2 DB3 DB4 DB5 DB6 DB7 NC NC DESCRIPTION Power supply for LCM GND Contrast Adjust Register Select Signal Data Read / Write Enable Signal Data bus line Data bus line Data bus line Data bus line Data bus line Data bus line Data bus line Data bus line No Connection No Connection Block Diagram REMARKS 5.0V Power Supply Diagram SINGLE SUPPLY TYPES U2 Vss Vdd SEG1--40 Vo 40 RS U1 R/W E 40 SEG1 SEG41-80 SEG80 V SS COM1 COM16 16 DB 0 8 Vdd V0 LCD 16 2 Vdd ~V 0 COM16 DB 7 R POT R LED BACKLIGHT MC21605DA6W-SPTLY-V2 2 x 16 Vdd 5mm Character Height Specification Version: 1 Revision Date: 20/10/2016 +5V LCD Module Font Map Upper 4bit Lower 4bit LLLL LLLH LLHL LLHH LHLL LHLH LHHL LHHH HLLL HLLH HLHL HLHH HHLL HHLH HHHL HHHH LLLL CG RAM (1) LLLH (2) LLHL (3) LLHH (4) LHLL (5) LHLH (6) LHHL (7) LHHH (8) HLLL (1) HLLH (2) HLHL (3) HLHH (4) HHLL (5) HHLH (6) HHHL (7) HHHH (8) MC21605DA6W-SPTLY-V2 2 x 16 5mm Character Height Specification Version: 1 Revision Date: 20/10/2016 LCD Module Absolute Maximum Ratings Item Symbol Condition Min Typ Max Unit Power Supply ( LOGIC) Vdd 25°C -0.3 --- 7.0 V Power Supply (LCD) V0 25°C Vdd -13.5 --- Vdd +0.3 V Input Voltage Vin Vopr 25°C ----- -0.3 --- Vdd +0.3 V -20 --- 70 C -30 --- 80 C Max Operating Temperature Storage Temperature Vstg Electronic Characteristics Item Symbol Condition Min Typ Input Voltage Vlcm = Vdd --- 5.0 Supply Current Idd Vdd=5V ----- Driving Voltage for LCD Panel Vlcd = (Vdd - V0) ----- 1.5 --- 4.90 --- 4.85 Unit V mA -20°C 0°C 4.45 4.35 25°C 4.25 4.50 4.80 50°C 4.15 --- 4.70 70°C 4.05 --- 4.60 Typ Max Unit --- --- Deg 10 150 150 --250 250 --ms ms V LCD Characteristics For STN/FSTN LCD Panel Types Item Symbol Viewing Angle Φ2 – Φ1 Θ Contrast Ratio Response Time (Rise) Response Time (Fall) K TR TF Condition K=4 ------- Min 40° 60° ------- LED Characteristics Item Symbol Condition Min Typ Max Unit LED Forward Voltage Vf 25°C If=5mA 2.8 --- 3.1 V LED Forward Current* If 25°C --- 5 --- mA LED Reverse Current Ir 25°C Vr=5.0V --- --- 10 A LED Peak Wave Length λp 25°C If= 5mA 569 --- 575 nm LED Brightness (Without LCD) Lv 25°C If= 5mA --- 88 --- cd/m 2 LED Brightness Uniformity Lvmin/Lvmax 25°C If= 5mA 70 --- --- Ratio 25°C If= 5mA 20K --- --- Hours LED Life Time Attention: It is constant current, not constant voltage, which should be applied when driving the LED backlight, please ensure you adhere to this rule. MC21605DA6W-SPTLY-V2 2 x 16 5mm Character Height Specification Version: 1 Revision Date: 20/10/2016 LCD Module
MC21605DA6W-SPTLY-V2 价格&库存
很抱歉,暂时无法提供与“MC21605DA6W-SPTLY-V2”相匹配的价格&库存,您可以联系我们找货
