MC21605G6WD-BNMLW-V2 数据手册
Electra House, 32 Southtown Road
Great Yarmouth, Norfolk
NR31 0DU, England
MC21605G6WD-BNMLW-V2 2 x 16
Version:
1
Telephone +44 (0)1493 602602
Email:sales@midasdisplays.com
www.midasdisplays.com
5mm Character Height
Specification
LCD Module
Date: 19/10/2016
Revision
Display Features
Character Count
2 x 16
White on Blue
Appearance
Logic Voltage
5V
Interface
Parallel
Font Set
English / Japanese
Display Mode
Transmissive
5.23mm
Character Height
FSTN
LC Type
80.00 x 36.00 x 11.00 mm
Module Size
Operating Temperature
-20°C ~ +70°C
Construction
COB
White
LED Backlight
Box Quantity
45 pcs
Weight / Display
28.88 grams
* - For full design functionality, please use this
specification in conjunction with the ST7066U
specification. (Provided Separately)
Display Accessories
Part Number
MCCMDB-16SIL
Description
LCD Interconnect board, can be
driven from either a PC or a
single Board computer with a
USB output.
MCCBL1A16SLIP
-16DILS-150
16 Way, Sinlge in-line to Dual
In-line connector Cable.
MCCBL1A16SLIP
-16SILS-150
16 Way, Single in-line to
Single In-line connector Cable.
Fonts
English/Euro
English/Cyrillic
Optional Variants
Appearances
Black on Yellow/
Green
Black on White
Black on RGB
Voltage
3V
3.3V
Mechanical Specifications
Module Size
80.00 x 36.00 x 11.00 ( With Backlight)
W x H x D mm
Viewing Area
64.50 x 16.40
W x H mm
Hole-to-Hole
75.00 x 31.00
W x H mm
Character Size
Dot Size
3.00 x 5.23
0.56 x 0.61
W x H mm
W x H mm
Character Pitch
Dot Pitch
0.51 x 0.52
0.05 x 0.05
W x H mm
W x H mm
Version:
1
2 x 16
Specification
Revision
Date: 19/10/2016
LCD Module
Pin Layout
PI
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
SYMBOL
Vss
Vdd
V0
RS
R/W
E
DB0
DB1
DB2
DB3
DB4
DB5
DB6
DB7
LED+
LED-
DESCRIPTION
GND
Power supply for LCM
Contrast Adjust
Register Select Signal
Data Read / Write
Enable Signal
Data bus line
Data bus line
Data bus line
Data bus line
Data bus line
Data bus line
Data bus line
Data bus line
Power supply for BKL
Vdd
RS
U1
R/W
E
DB 0
40
40
SEG1
COM16 16
8
5.0V
SINGLE SUPPLY TYPES
U2
Vss
SEG1--40
5.0V
Power Supply Diagram
Block Diagram
Vo
REMARKS
COM1
SEG41-80
SEG80
V SS
Vdd
V0
LCD 16 2
Vdd ~V 0
COM16
DB 7
R POT
PIN15
R
LED BACKLIGHT
PIN16
Vdd
+5V
RPOT: 10K-20K
Version:
1
2 x 16
Specification
Revision
Date: 19/10/2016
LCD Module
Font Map
Upper
4bit
Lower
4bit
LLLL LLLH LLHL LLHH LHLL LHLH LHHL LHHH HLLL HLLH HLHL HLHH HHLL HHLH HHHL HHHH
LLLL
CG
RAM
(1)
LLLH
(2)
LLHL
(3)
LLHH
(4)
LHLL
(5)
LHLH
(6)
LHHL
(7)
LHHH
(8)
HLLL
(1)
HLLH
(2)
HLHL
(3)
HLHH
(4)
HHLL
(5)
HHLH
(6)
HHHL
(7)
HHHH
(8)
Version:
1
2 x 16
Specification
Revision
Date: 19/10/2016
LCD Module
Absolute Maximum Ratings
Item
Symbol
Condition
Min
Typ
Max
Unit
Power Supply ( LOGIC)
Vdd
25°C
-0.3
7.0
V
Power Supply (LCD)
V0
25°C
Vdd -13.5
Vdd +0.3
V
Input Voltage
Vdd +0.3
V
70
C
Storage Temperature
Vstg
25°C
-0.3
Vin
Vopr
80
C
-20
-30
Electronic Characteristics
Item
Symbol
Condition
Min
Typ
Max
Unit
Input Voltage
Vlcm = Vdd
5.0
Idd
Vdd=5V
V
Supply Current
Driving Voltage for
LCD Panel
Vlcd = (Vdd - V0)
-20 °C
0°C
3.85
3.80
25 °C
1.5
mA
4.25
4.30
3.75
4.00
4.30
50 °C
3.65
4.20
70 °C
3.55
4.10
Typ
Max
Unit
Deg
10
150
150
--250
250
--ms
ms
V
LCD Characteristics
For STN/FSTN LCD Panel Types
Item
Symbol
Viewing Angle
Contrast Ratio
Response Time (Rise)
Response Time (Fall)
Φ2 – Φ1
Θ
K
TR
TF
Condition
K=4
Min
40°
60°
LED Characteristics
Item
Symbol
Condition
Min
Typ
Max
Unit
LED Forward Voltage
Vf
25°C If=15mA
5.0
V
LED Forward Current*
If
25°C
15
mA
LED Reverse Current
Ir
25°C Vr=5.0V
10
µA
0.26
0.30
0.27
0.31
LED Colour Range
X Coordinate
Y Coordinate
25°C If=15mA
LED Brightness (Without LCD)
Lv
25°C If=15mA
325
cd/m 2
LED Brightness Uniformity
Lvmin/Lvmax
25°C If=15mA
70
Ratio
LED Life Time
25°C If=15mA
9K
Hours
Attention: It is constant current, not constant voltage, which should be applied when driving
the LED backlight, please ensure you adhere to this rule.
Version:
1
2 x 16
Specification
Revision
Date: 19/10/2016
LCD Module
MC21605G6WD-BNMLW-V2 价格&库存
很抱歉,暂时无法提供与“MC21605G6WD-BNMLW-V2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+86.17451
- 10+83.60229
