MC21609AB6W-BNMLW-V2 数据手册
Electra House, 32 Southtown Road
Great Yarmouth, Norfolk
NR31 0DU, England
2 x 16
Telephone +44 (0)1493 602602
Fax +44 (0)1493 665111
Email:sales@midasdisplays.com
www.midasdisplays.com
9mm Character Height
LCD Module
Specification
Version:
1
Date: 29/09/2016
Revision
Display Features
Character Count
2 x 16
Appearance
White on Blue
Logic Voltage
5V
Interface
Parallel
Font Set
English / Japanese
Transmissive
Display Mode
9.66mm
Character Height
BSTN
LC Type
Module Size
122.00 x 44.00 x 13.50 mm
Operating Temperature
-20°C ~ +70°C
Construction
COB
White
LED Backlight
Box Quantity
30 pcs
Weight / Display
60 grams
* - For full design functionality, please use this
specification in conjunction with the ST7066U
specification. (Provided Separately)
Display Accessories
Part Number
MCCMDB-16SIL
Description
LCD Interconnect board, can be
driven from either a PC or a
single Board computer with a
USB output.
MCCBL1A16SLIP
-16DILS-150
16 Way, Single in-line to
Dual In-line connector Cable.
MCCBL1A16SLIP
-16SILS-150
Single In-line connector Cable.
Optional Variants
Fonts
Appearances
Black on
Yellow/Green
Black on White
Voltage
Mechanical Specifications
122.00 x 44.00 x 13.5 ( With Backlight)
Module Size
W x H x D mm
Viewing Area
99.00 x 24.00
W x H mm
Hole-to-Hole
115.00 x 37.00
W x H mm
Character Size
Dot Size
4.84 x 9.66
0.92 x 1.10
W x H mm
W x H mm
Character Pitch
Dot Pitch
1.16 x 0.68
W mm
W x H mm
2 x 16
0.06 x 0.06
Specification
Version:
1
Date: 29/09/2016
Revision
LCD Module
Pin Layout
PI
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
SYMBOL
Vss
Vdd
V0
RS
R/W
E
DB0
DB1
DB2
DB3
DB4
DB5
DB6
DB7
LEDLED+
DESCRIPTION
GND
Power supply for LCM
Contrast Adjust
Register Select Signal
Data Read / Write
Enable Signal
Data bus line
Data bus line
Data bus line
Data bus line
Data bus line
Data bus line
Data bus line
Data bus line
Power supply for BKL
Block Diagram
REMARKS
5.0V
5.0V
Power Supply Diagram
SINGLE SUPPLY TYPES
U2
Vss
Vdd
SEG1--40
Vo
40
RS
U1
R/W
E
40
SEG1
SEG41-80
SEG80
V SS
COM1
COM16 16
DB 0
8
Vdd
V0
LCD 16 2
Vdd ~V 0
COM16
DB 7
R POT
PIN16
R
LED BACKLIGHT
Vdd
PIN15
+5V
RPOT: 10K-20K
2 x 16
Specification
Version:
1
Date: 29/09/2016
Revision
LCD Module
Font Map
Upper
4bit
Lower
4bit
LLLL LLLH LLHL LLHH LHLL LHLH LHHL LHHH HLLL HLLH HLHL HLHH HHLL HHLH HHHL HHHH
LLLL
CG
RAM
(1)
LLLH
(2)
LLHL
(3)
LLHH
(4)
LHLL
(5)
LHLH
(6)
LHHL
(7)
LHHH
(8)
HLLL
(1)
HLLH
(2)
HLHL
(3)
HLHH
(4)
HHLL
(5)
HHLH
(6)
HHHL
(7)
HHHH
(8)
2 x 16
Specification
Version:
1
Date: 29/09/2016
Revision
LCD Module
Absolute Maximum Ratings
Item
Symbol
Condition
Min
Typ
Max
Unit
Power Supply ( LOGIC)
Vdd
25 °C
-0.3
7.0
V
Power Supply (LCD)
V0
25 °C
Vdd -13.5
Vdd +0.3
V
Input Voltage
Vin
Vopr
25 °C
-0.3
Vdd +0.3
V
-20
70
°C
-30
80
°C
Storage Temperature
Vstg
Electronic Characteristics
Item
Symbol
Condition
Min
Typ
Max
Unit
Input Voltage
Vlcm = Vdd
5.0
Idd
Vdd=5V
V
Supply Current
Driving Voltage for
LCD Panel
Vlcd = (Vdd - V0)
-20 °C
0°C
4.30
4.20
25 °C
1.5
mA
4.55
4.6
4.10
4.50
4.60
50 °C
4.20
4.60
70 °C
4.00
4.50
Typ
Max
Unit
Deg
10
150
150
--250
250
--ms
ms
V
LCD Characteristics
For STN/FSTN LCD Panel Types
Item
Symbol
Viewing Angle
Φ2 – Φ1
Θ
Contrast Ratio
Response Time (Rise)
Response Time (Fall)
K
TR
TF
Condition
K=4
Min
40°
60°
LED Characteristics
Item
Symbol
Condition
Min
Typ
Max
Unit
LED Forward Voltage
Vf
25°C If=30mA
5.0
V
LED Forward Current*
If
25°C
30
mA
LED Reverse Current
Ir
25°C Vr=5.0V
µA
0.26
0.30
0.27
0.31
X Coordinate
25°C If=30mA
LED Colour Range
Y Coordinate
LED Brightness (Without LCD)
Lv
25°C If=30mA
440
cd/m 2
LED Brightness Uniformity
Lvmin/Lvmax
25°C If=30mA
70
Ratio
LED Life Time
25°C If=30mA
50k
Hours
Attention: It is constant current, not constant voltage, which should be applied when driving
the LED backlight, please ensure you adhere to this rule.
2 x 16
Specification
Version:
1
Date: 29/09/2016
Revision
LCD Module
MC21609AB6W-BNMLW-V2 价格&库存
很抱歉,暂时无法提供与“MC21609AB6W-BNMLW-V2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+180.10732
- 10+177.58717
- 50+174.04646
