MC42005A6W-FPTLW-V2
MC42005A6W-FPTLW-V2
    MIDAS
    4X20 CHARACTER CHIP-ON-BOARD LCD
MC42005A6W-FPTLW-V2 数据手册
Electra House, 32 Southtown Road Great Yarmouth, Norfolk NR31 0DU, England MC42005A6W-FPTLW-V2 4 x 20 5mm Character Height Specification Version: Telephone +44 (0)1493 602602 Fax +44 (0)1493 665111 Email:sales@midasdisplays.com www.midasdisplays.com LCD Module Date: 31/10/2016 1 Revision Display Features Character Count Appearance Logic Voltage Interface Font Set Display Mode Character Height LC Type Module Size Operating Temperature Construction LED Backlight 4 x 20 Black on White 5V Parallel English / Japanese Transflective 4.75mm FSTN 98.00 x 60.00 x 14.00 mm -20°C ~ +70°C COB White Box Quantity 30 pcs Weight / Display 75 grams * - For full design functionality, please use this specification in conjunction with the ST7066U specification. (Provided Separately) Display Accessories Part Number MCCMDB-16SIL Description LCD Interconnect board, can be driven from either a PC or a single Board computer with a USB output. MCCBL1A16SLIP -16DILS-150 16 Way, Sinlge in-line to Dual In-line connector Cable. MCCBL1A16SLIP -16SILS-150 16 Way, Single in-line to Single In-line connector Cable. Optional Variants Fonts Appearances Black on Yellow/Green White on Blue Voltage 3V Mechanical Specifications 98.00 x 60.00 x 14.00 ( With Backlight) Module Size W x H x D mm Viewing Area 76.00 x 25.20 W x H mm Hole-to-Hole 93.00 x 55.00 W x H mm Character Size Dot Size 2.95 x 4.75 0.55 x 0.55 W x H mm W x H mm Character Pitch Dot Pitch 0.60 x 0.60 0.05 x 0.05 W x H mm W x H mm MC42005A6W-FPTLW-V2 4 x 20 5mm Character Height Specification Version: 1 Revision Date: 31/10/2016 LCD Module Pin Layout PI 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 SYMBOL Vss Vdd V0 RS R/W E DB0 DB1 DB2 DB3 DB4 DB5 DB6 DB7 LED+ LED- DESCRIPTION GND Power supply for LCM Contrast Adjust Register Select Signal Data Read / Write Enable Signal Data bus line Data bus line Data bus line Data bus line Data bus line Data bus line Data bus line Data bus line Power supply for BKL Power supply for BKL REMARKS 5.0V 5.0V Power Supply Diagram Block Diagram SINGLE SUPPLY TYPES Vss Vdd Vo RS R/W E U2 U1 U3 SEG1--40 SEG41--120 40 DB 0 8 SEG1 80 SEG121--200 V SS 80 V0 Vdd SEG200 Vdd ~V 0 COM1 DB 7 LCD 20 4 COM16 16 COM16 R POT PIN15 R Vdd LED BACKLIGHT PIN16 MC42005A6W-FPTLW-V2 4 x 20 5mm Character Height Specification Version: 1 Revision Date: 31/10/2016 +5V LCD Module Font Map Upper 4bit Lower 4bit LLLL LLLH LLHL LLHH LHLL LHLH LHHL LHHH HLLL HLLH HLHL HLHH HHLL HHLH HHHL HHHH LLLL CG RAM (1) LLLH (2) LLHL (3) LLHH (4) LHLL (5) LHLH (6) LHHL (7) LHHH (8) HLLL (1) HLLH (2) HLHL (3) HLHH (4) HHLL (5) HHLH (6) HHHL (7) HHHH (8) MC42005A6W-FPTLW-V2 4 x 20 5mm Character Height Specification Version: 1 Revision Date: 31/10/2016 LCD Module Absolute Maximum Ratings Item Symbol Condition Min Typ Max Unit Power Supply ( LOGIC) Vdd 25°C -0.3 --- 7.0 V Power Supply (LCD) V0 25°C Vdd -13.5 --- Vdd +0.3 V Input Voltage Vin Vopr 25°C ----- -0.3 --- Vdd +0.3 V -20 --- 70 C -30 --- 80 C Max Operating Temperature Storage Temperature Vstg Electronic Characteristics Item Symbol Condition Min Typ Input Voltage Vlcm = Vdd --- 5.0 5.5 V Supply Current Idd Vdd=3V 4.5 --- --- mA -20°C 0°C 4.40 4.30 1.5 --- 5.00 --- 4.90 25°C 4.20 4.50 4.80 50°C 4.10 --- 4.70 70°C 4.00 --- 4.60 Driving Voltage for LCD Panel Vlcd = (Vdd - V0) Unit V LCD Characteristics For STN/FSTN LCD Panel Types Item Symbol Viewing Angle Φ2 – Φ1 Θ Contrast Ratio Response Time (Rise) Response Time (Fall) K TR TF Condition K=4 ------- Min 40° 60° ------- Typ Max Unit --- --- Deg 10 150 150 --250 250 --ms ms LED Characteristics Item Symbol Condition Min Typ Max Unit LED Forward Voltage Vf 25°C If=2*15mA --- 5.0 --- V LED Forward Current* If 25°C --- 15 --- mA LED Reverse Current Ir 25°C Vr=5.0V --- --- 20 µA 0.26 --- 0.30 --- 0.27 --- 0.31 --- X Coordinate LED Colour Range 25°C If=2*15mA Y Coordinate LED Brightness (Without LCD) Lv 25°C If=2*15mA --- 550 --- cd/m 2 LED Brightness Uniformity Lvmin/Lvmax 25°C If=2*15mA 70 --- --- Ratio LED Life Time --- 25°C If=2*15mA 9K --- --- Hours Attention: It is constant current, not constant voltage, which should be applied when driving the LED backlight, please ensure you adhere to this rule. MC42005A6W-FPTLW-V2 4 x 20 5mm Character Height Specification Version: 1 Revision Date: 31/10/2016 LCD Module
MC42005A6W-FPTLW-V2 价格&库存
很抱歉,暂时无法提供与“MC42005A6W-FPTLW-V2”相匹配的价格&库存,您可以联系我们找货
MC42005A6W-FPTLW-V2
  • 1+222.41874
  • 10+220.26307
  • 50+216.28499
库存:558
