MCCOG21605B6W-SPTLYI
    MIDAS
    2X16 CHARACTER CHIP-ON-GLASS LCD
MCCOG21605B6W-SPTLYI 数据手册
Electra House, 32 Southtown Road Great Yarmouth, Norfolk NR31 0DU, England MCCOG21605B6W-SPTLYI 2 x 16 5mm Character Height Specification Version: Telephone +44 (0)1493 602602 Email:sales@midasdisplays.com www.midasdisplays.com 1 LCD Module Date: 19/10/2016 Revision Display Features Character Count Appearance Logic Voltage Interface Font Set Display Mode Character Height LC Type Module Size Operating Temperature Construction LED Backlight 2 x 16 Black on Yellow/Green 5V I2C English / Japanese Transflective 3.79mm STN 51.20 x 20.70 x 6.30 mm -20°C ~ +70°C COG Yellow/Green Box Quantity --- Weight / Display --- * - For full design functionality, please use this specification in conjunction with the ST7032I specification. (Provided Separately) Display Accessories Part Number MCCOG-I2C-I-8 Description Fine pitch(1.27mm) COG I2C interface board. Compatible with both Arduino and UC32 controller boards. Optional Variants Fonts Appearances Black on White White on Blue Voltage Mechanical Specifications 51.20 x 20.70 x 6.30 ( With Backlight) Module Size W x H x D mm Viewing Area 40.00 x 10.00 W x H mm Hole-to-Hole --- W x H mm Character Size Dot Size 2.00 x 3.79 0.36 x 0.43 W x H mm W x H mm Character Pitch Dot Pitch 2.40 x 4.19 0.41 x 0.48 W x H mm W x H mm K 6.8 A 6.3 0.3 2.8MAX 1.1 1.1 3.0 2.0 9.3 10.0 2.0 DOT SIZE SCALE 5/1 2.00 0.41 0.36 8 18.155 0.7 2 x 16 5.5 20.7 18.5 13.0 VA10.0 AA8.0 1.1 2.6 3.6 ±5° 1 0.4 ST7032i 51.2 3.79 0.48 0.43 43.0 VA40.0 AA38.0 0.40 P1.27*7=8.89 0.40 0.6 1.15 17.2 3.6 1.1 2.6 MCCOG21605B6W-SPTLYI 5mm Character Height Specification Version: 1 Revision Date: 19/10/2016 LCD Module Pin Layout PI 1 2 3 4 5 6 7 8 SYMBOL VOUT CAP1N CAP1P VDD VSS SDA SCL RST MCCOG21605B6W-SPTLYI DESCRIPTION DC/DC Voltage Converter Voltage booster Circuit (VDD-VSS) 5.0V Power Supply Ground Input Data Clock Input Data Reset 2 x 16 5mm Character Height Specification Version: REMARKS 1 Revision Date: 19/10/2016 LCD Module Font Map Upper 4bit Lower 4bit LLLL LLLH LLHL LLHH LHLL LHLH LHHL LHHH HLLL HLLH HLHL HLHH HHLL HHLH HHHL HHHH LLLL CG RAM (1) LLLH (2) LLHL (3) LLHH (4) LHLL (5) LHLH (6) LHHL (7) LHHH (8) HLLL (1) HLLH (2) HLHL (3) HLHH (4) HHLL (5) HHLH (6) HHHL (7) HHHH (8) MCCOG21605B6W-SPTLYI 2 x 16 5mm Character Height Specification Version: 1 Revision Date: 19/10/2016 LCD Module Absolute Maximums Ratings Item Symbol Minimum Typical Maximum Unit Power Supply (Logic) Vdd -0.3 --- 6.0 V Power Supply (LCD) V0 7.0 -Vss --- -0.3 +Vss V --- --- --- --- --- TOP TST -20°C -30°C ----- 70°C 80°C °C °C --Operating Temperature Storage temperature Electronic Characteristics Item Input Voltage High Input Voltage Low Output Voltage High Output Voltage Low Supply Voltage Logic Supply Voltage LCD Supply Current Symbol Condition VIH VIL VOH VOL VDD ~ VSS VDD ~ V0 IDD ----------Ta=25°C --- Minimum 0.70 --0.80 --3.00 ----- Typical Maximum Unit --------3.30 4.50 0.17 VDD 0.20 VDD 0.20 5.00 ----- V V V V V V mA LCD Characteristics For STN/FSTN LCD Panel Types Item Symbol Condition Viewing Angle Contrast Ratio Response Time (Rise) Response Time (Fall) Φ2 – Φ1 Θ CR Minimum CR ≥ 2 ----- Typical 20 -30 --- Maximum 3 40 30 --- Unit ψ=180° --- TR --- --- 250 400 ms TF --- --- 100 250 ms Maximum Unit LED Characteristics Item Symbol Condition Supply Current Supply Voltage Reverse Voltage Luminance (Without LCD) Wave Length LED Life Time ILED V VR V=3.5V ----- Minimum 28.80 3.40 --- Typical IV ILED=32mA 892 1116 --- Cd/m2 λp --- ILED=32mA ILED=32mA 565 --- --50K 575 --- --Hour 32 3.50 --- 50 3.60 5 mA V V Attention: It is constant current, not constant voltage, which should be applied when driving the LED backlight, please ensure you adhere to this rule. MCCOG21605B6W-SPTLYI 2 x 16 5mm Character Height Specification Version: 1 Revision Date: 19/10/2016 LCD Module
MCCOG21605B6W-SPTLYI 价格&库存
很抱歉,暂时无法提供与“MCCOG21605B6W-SPTLYI”相匹配的价格&库存,您可以联系我们找货
