MDT1010GIHR-HDMI
MDT1010GIHR-HDMI
    MIDAS
    LCD DISPLAY TFT 10.1 1280X800
MDT1010GIHR-HDMI 数据手册
Electra House, 32 Southtown Road Great Yarmouth, Norfolk NR31 0DU, England (MCT101HDMI-A-RTP) Version: HDMI Interface 1280 x 800 MDT1010GIHR-HDMI Specification 1 1 26/06/2019 Telephone +44 (0)1493 602602 Fax +44 (0)1493 665111 Email:sales@midasdisplays.com www.midasdisplays.com TFT Module Date: 28/06/2019 Revision First issue Display Features Display Size 10.10” Resolution 1280 x 800 Orientation Landscape RGB Appearance 5V Logic Voltage HDMI Interface Brightness 750 cd/m2 RTP Touchscreen Module Size 230.56 x 155.01 x 28.40mm Operating Temperature -20°C ~ +70°C Pinout 40 Way Connector --Pitch Box Quantity --- Weight / Display --- * - For full design functionality, please use this specification in conjunction with the TFP401 specification. (Provided Separately) Display Accessories Part Number Description HDMI-to-HDMI interconnect MCIB-HDMI/HDMI board. MCIC-USB Type-A USB to Micro-B USB interconnect cable. Optional Variants Appearances Capacitive Touch Panel No Touch Panel Voltage Summary TFT 10.1” is a IPS transmissive type color active matrix TFT liquid crystal display . InPlane Switching (IPS) was one of the first refinements to produce significant gains in the light-transmissive characteristics of TFT panels. It is a technology that addresses the two main issues of a standard twisted nematic (TN) TFT display: colour and viewing angle. General Specifications  Screen Diagonal: 10.1  Number of Pixels: 1280 x 3(R GB) x 800  Module dimension: 230.56 x 155.01 x 28.4(max)  Active area: 216.96 (H) x 135.6(V)  Pixel pitch: 0.1695 × 0.1695  Display Mode: Normally Black  Pixel Arrangement: R.G.B. Vertical Stripe  Backlight Type: LED,Normally White  Aspect Ratio: 16:9  Electrical Interface (Logic): HDMI  RTP Interface:USB  With /Without TP: With RTP  Surface: Anti-Glare *Color tone slight changed by temperature and driving voltage. Interface CON6 Pin No. Symbol Function Remark 1 3.3V TFT Module Power limit can only output 3.3V,100mA Note1 2 5V 3 GPIO02 4 5V 5 GPIO03 6 GND 7 GPIO04 Raspberry Pi:GPIO04 8 GPIO14 Raspberry Pi:GPIO14 9 GND 10 GPIO15 Raspberry Pi:GPIO15 11 GPIO17 Raspberry Pi:GPIO17 12 GPIO18 Raspberry Pi:GPIO18 (Backlight Enable) 13 GPIO27 Raspberry Pi:GPIO27 14 GND 15 GPIO22 Raspberry Pi:GPIO22 16 GPIO23 Raspberry Pi:GPIO23 17 3.3V 18 GPIO24 Raspberry Pi:GPIO24 19 GPIO10 Raspberry Pi:GPIO10 20 GND 21 GPIO09 Raspberry Pi:GPIO09 22 GPIO25 Raspberry Pi:GPIO25 23 GPIO11 Raspberry Pi:GPIO11 24 GPIO08 Raspberry Pi:GPIO08 25 GND 26 GPIO07 27 ID_SD Raspberry Pi:ID_SD 28 ID_SC Raspberry Pi:ID_SC 29 GPIO05 30 GND 31 GPIO06 Raspberry Pi:GPIO06 32 GPIO12 Raspberry Pi:GPIO12 Raspberry Pi:Power 5V Raspberry Pi:GPIO02 Raspberry Pi:Power 5V Raspberry Pi:GPIO03 Raspberry Pi:GND Raspberry Pi:GND Raspberry Pi:GND TFT Module Power limit can only output 3.3V,100mA Raspberry Pi:GND Raspberry Pi:GND Raspberry Pi:GPIO07 Raspberry Pi:GPIO05 Raspberry Pi:GND Note1 33 GPIO13 Raspberry Pi:GPIO13 34 GND 35 GPIO19 Raspberry Pi:GPIO19 36 GPIO16 Raspberry Pi:GPIO16 37 GPIO26 Raspberry Pi:GPIO26 38 GPIO20 Raspberry Pi:GPIO20 39 GND 40 GPIO21 Raspberry Pi:GND Raspberry Pi:GND Raspberry Pi:GPIO21 Note1: The 3.3V supply current is limited; please pay special attention to use CON5 Pin No. Symbol Function 1 NC No connection 2 5V Raspberry Pi:Power 5V 3 GPIO02 4 5V 5 GPIO03 6 GND 7 GPIO04 Raspberry Pi:GPIO04 8 GPIO14 Raspberry Pi:GPIO14 9 GND 10 GPIO15 Raspberry Pi:GPIO15 11 GPIO17 Raspberry Pi:GPIO17 12 GPIO18 Raspberry Pi:GPIO18 (Backlight Enable) 13 GPIO27 Raspberry Pi:GPIO27 14 GND 15 GPIO22 Raspberry Pi:GPIO22 16 GPIO23 Raspberry Pi:GPIO23 17 NC 18 GPIO24 Raspberry Pi:GPIO24 19 GPIO10 Raspberry Pi:GPIO10 20 GND 21 GPIO09 Raspberry Pi:GPIO09 22 GPIO25 Raspberry Pi:GPIO25 23 GPIO11 Raspberry Pi:GPIO11 24 GPIO08 Raspberry Pi:GPIO08 25 GND 26 GPIO07 27 ID_SD Raspberry Pi:ID_SD 28 ID_SC Raspberry Pi:ID_SC 29 GPIO05 30 GND 31 GPIO06 Raspberry Pi:GPIO06 32 GPIO12 Raspberry Pi:GPIO12 33 GPIO13 Raspberry Pi:GPIO13 Raspberry Pi:GPIO02 Raspberry Pi:Power 5V Raspberry Pi:GPIO03 Raspberry Pi:GND Raspberry Pi:GND Raspberry Pi:GND No connection Raspberry Pi:GND Raspberry Pi:GND Raspberry Pi:GPIO07 Raspberry Pi:GPIO05 Raspberry Pi:GND Remark 34 GND 35 GPIO19 Raspberry Pi:GPIO19 36 GPIO16 Raspberry Pi:GPIO16 37 GPIO26 Raspberry Pi:GPIO26 38 GPIO20 Raspberry Pi:GPIO20 39 GND 40 GPIO21 HDMI Pin No. Raspberry Pi:GND Raspberry Pi:GND Raspberry Pi:GPIO21 Symbol I/O Function 1 Rx2+ I +LVDS Differential Data Input 2 GND P Ground 3 Rx2- I -LVDS Differential Data Input 4 Rx1+ I +LVDS Differential Data Input 5 GND P Ground 6 Rx1- I -LVDS Differential Data Input 7 Rx0+ I +LVDS Differential Data Input 8 GND P Ground 9 Rx0- I -LVDS Differential Data Input 10 RxC+ I +LVDS Differential Clock Input 11 GND P Ground 12 RxC- I -LVDS Differential Clock Input 13-14 NC - No connection 15 SCL I/O DDC(Data Display Channel) Clock 16 SDA I/O DDC(Data Display Channel) Data 17 GND P Ground 18 5V P Power Supply 19 Detect I/O Hot plug detect I: input, O: output, P: Power Remark POWER-JACK Pin No. Symbol I/O Function 1 5V P Power Supply (5V) 2 GND P Ground 3 NC - No connection Remark USB Pin Symbol Function 1 5V Power Supply (5V) 2 D- Data line - 3 D+ Data line + 4 NC No connection 5 GND Power Ground Remark Contour Drawing TP OUTLINE 228.34¡ À 0.2 4.42¡ À 0.5 (4.92) TP VA 218.00 TP AA 217.00 TFT AA 216.96 4.94 11.11 6.74¡ À 0.5 9.00¡ À 0.5 10.41¡ À 0.5 (10.91) TFT OUTLINE 230.56 0.54¡ 0À.5 1.6(PCB) 14.1MAX RGB TP AA 136.00 TFT AA 135.60 TP VA 137.00 TFT OUTLINE 155.01 TP OUTLINE 147.98¡ À 0.2 9.0MAX 1280 X RGB X 800 11.5MAX 28.4MAX The non-specified tolerance of dimension is ¡ À 0.3 mm . CON5 Pin Symbol Pin Symbol HDMI 230.00¡ À 0.5(PCB) 0.28¡ À 0.5 3.50 105.00 112.00¡ À 0.5(PCB) 3.50 223.00 VLED+ VLED- CON6 Pin Symbol Pin Symbol NC 21 GPIO09 1 3.3V 21 GPIO09 2 5V 22 GPIO25 2 5V 22 GPIO25 3 GPIO02 23 GPIO11 3 GPIO02 23 GPIO11 4 5V 24 GPIO08 4 5V 24 GPIO08 5 GPIO03 25 GND 5 GPIO03 25 GND 6 GND 26 GPIO07 6 GND 26 GPIO07 7 GPIO04 27 ID_SD 7 GPIO04 27 ID_SD 8 GPIO14 28 ID_SC 8 GPIO14 28 ID_SC 9 GND 29 GPIO05 9 GND 29 GPIO05 10 GPIO15 30 GND 10 GPIO15 30 GND 11 GPIO17 31 GPIO06 11 GPIO17 31 GPIO06 12 GPIO18 GPIO12 32 GPIO12 12 GPIO18 32 13 GPIO27 33 GPIO13 13 GPIO27 33 14 GND 34 GND 14 GND 34 GND 15 GPIO22 35 GPIO19 15 GPIO22 35 GPIO19 16 GPIO23 36 GPIO16 16 GPIO23 36 GPIO16 17 NC 37 GPIO26 17 3.3V 37 GPIO26 18 GPIO24 38 GPIO20 18 GPIO24 38 GPIO20 19 GPIO10 39 GND 19 GPIO10 39 GND 20 GND 40 GPIO21 20 GND 40 GPIO21 POWER JACK Down side pitch=0.5mm 8- 2.75PTH 8- 6.20PAD Lcm Connector (20.00) 40 17.50 PCB RX2+ GND RX2RX1+ GND RX1RX0+ GND RX0RXC+ GND RXCNC NC SCL SDA GND 5V Detect 21.50¡ 0 À.5 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 1 171.00 PCB 1 (26.21) 1 2 3 2 (GND) 5V GND NC 1 (5V) GPIO13 USB 1 2 3 4 5 5V DD+ NC GND The non-specified tolerance of dimension is ¡ 0À.3 mm . Absolute Maximum Ratings Item Symbol Min Typ Max Unit Operating Temperature TOP -20 - +70 ℃ Storage Temperature TST -20 - +70 ℃ Note: Device is subject to be damaged permanently if stresses beyond those absolute maximum ratings listed above 1. Temp. ≦60℃, 90% RH MAX. Temp.>60℃, Absolute humidity shall be less than 90% RH at 60℃ Electrical Characteristics Operating conditions: Item Symbol Condition Min Typ Max Unit Remark Supply Voltage For LCM VDD - 4.9 5 5.1 V - Supply Current For LCM IDD - - 1.9 2.7 A Note 1 - - 50000 - - Hr Note 4 LED life time Note 1 : This value is test for VDD =5.0V , Ta=25℃ only Note 2 : Display with Raspberry pi the driver power is over USB , first make sure you have a 3A power supply, with a good quality USB cable, a thin wire power cable is no good. Make sure its 24AWG or smaller, shorter USB cables are better too. Note3 : Touch Panel driver is base on the mouse driver program and through USB port connect to PC or embedded board.Can only support the single touch. Note 4: The “LED life time” is defined as the module brightness decrease to 50% original brightness at Ta=25℃ and IL =480mA. The LED lifetime could be decreased if operating IL is lager than 480mA. LVDS Signal Timing Characteristics AC Electrical Characteristics Parameter LVDS Differential input high Threshold voltage LVDS Differential input low Threshold voltage LVDS Differential input common mode voltage LVDS Differential voltage Symbol Min. Values Typ. MAX. Unit RxVTH - - +100 mV RxVTL -100 - - mV RxVCM 0.7 - 1.6 V |VID| 200 - 600 mV Remark RXVCM=1.2 V Timing Table Parameter Symbol Clock Frequency 1/Tc Horizontal display area thd HS period time th HS Width +Back Porch +Front Porch tHW+ tHBP +tHFP Vertical display area tvd VS period time tv VS Width +Back Porch +Front Porch tvW+ tvBP +tvFP Value Min. Typ. Max. 68.9 71.1 73.4 1280 Unit Mhz Tc 1410 1440 1470 Tc 60 160 190 Tc 800 tH 815 823 833 tH 15 23 33 tH Remark Frame rate =60Hz LVDS Data Input Format Optical Characteristics Item Symbol Response time Contrast ratio Color Chromaticity White Hor. Viewing angle Ver. Tr Tf CR Wx Wy Condition. θ=0°、Φ=0° At optimized viewing angle θ=0°、Φ=0 ΘR ΘL ΦT CR≧10 ΦB Min Typ. Max. Unit Remark .ms Note 3 Note 4 - 10 20 - 15 30 600 800 - - 0.26 0.31 0.36 - 0.28 0.33 0.38 - 75 85 - 75 85 - 75 85 - 75 85 - Note 2,6,7 Deg. Note 1 Center of display Note5 Brightness - - 700 750 - cd/m2 Uniformity (U) - 70 - - % Ta=25±2℃ Note 1: Definition of viewing angle range Fig. 9.1. Definition of viewing angle Note 2: Test equipment setup: After stabilizing and leaving the panel alone at a driven temperature for 10 minutes, the measurement should be executed. Measurement should be executed in a stable, windless, and dark room. Optical specifications are measured by Topcon BM-7 or BM-5 luminance meter 1.0° field of view at a distance of 50cm and normal direction. Fig. 9.2. Optical measurement system setup Note 3: Definition of Response time: The response time is defined as the LCD optical switching time interval between “White” state and “Black” state. Rise time, Tr, is the time between photo detector output intensity changed from 90%to 10%. And fall time, Tf, is the time between photo detector output intensity changed from 10%to 90% Display Data White(TFT OFF) Black(TFT ON) White(TFT OFF) 100% 90% 10% 0% Note 4: Definition of contrast ratio: The contrast ratio is defined as the following expression. Contrast ratio (CR) = Luminance measured when LCD on the "White" state Luminance measured when LCD on the "Black" state Note 5: Definition of Luminance Uniformity Active area is divided into 9 measuring areas (reference the picture in below). Every measuring point is placed at the center of each measuring area. Luminance Uniformity (U) = Lmin/Lmax x100% L = Active area length W = Active area width Fig 9.3. Definition of uniformity Note 6: Definition of color chromaticity (CIE 1931) Color coordinates measured at the center point of LCD Note 7: Measured at the center area of the panel when all the input terminals of LCD panel are electrically opened. Reliability Content of Reliability Test (Wide temperature, -20℃~70℃) Environmental Test Test Item High Temperature storage Low Temperature storage High Temperature Operation Content of Test Endurance test applying the high storage temperature for a long time. Endurance test applying the low storage temperature for a long time. Endurance test applying the electric stress (Voltage & Current) and the thermal stress to the element for a long time. Low Temperature Endurance test applying the electric stress Operation under low temperature for a long time. High Temperature/ The module should be allowed to stand at 60 Humidity Operation ℃,90%RH max Thermal shock The sample should be allowed stand the following 10 cycles of operation resistance -20℃ 25℃ 70℃ 30min Test Condition 70℃ 200hrs -20℃ 200hrs 70℃ 200hrs -20℃ 200hrs 60℃,90%RH 96hrs -20℃/70℃ 10 cycles Note 2 1,2 —— 1 1,2 —— 5min 30min 1 cycle Vibration test Endurance test applying the vibration during Total fixed 3 transportation and using. amplitude : 1.5mm Vibration Frequency : 10~55Hz One cycle 60 seconds to 3 directions of X,Y,Z for Each 15 minutes Static electricity test Endurance test applying the electric stress to VS=±600V(contact) —— the terminal. , ±800v(air), RS=330Ω CS=150pF 10 times Note1: No dew condensation to be observed. Note2: The function test shall be conducted after 4 hours storage at the normal Temperature and humidity after remove from the test chamber. Note3: The packing have to including into the vibration testing. Touch Panel Information 227.94¡ Ó 0.30 218.00¡ Ó 0.20 (VA) 2.60¡ Ó 0.20 4.38¡ Ó 0.20 217.00¡ Ó 0.20 (AA) 1.40¡ Ó 0.15 5.67¡ Ó 0.30 SYMBOL 1 XL 2 YD 3 XR 4 YU 2.87¡ Ó0.30 228.34¡ Ó 0.20 (TP) 3.88¡ Ó 0.20 Pin No. 219.20¡ Ó 0.30 T=0.05mm 0.30¡ Ó 0.05 PIN Logic 1 2 XL YD 3 XR 4 YU 5.50¡ Ó0.30 2*1.00¡ Ó 0.10 W=4*0.70¡ Ó 0.05 P:1.00*3=3.00¡ Ó 0.10 3.19¡ Ó0.50 PIN4 23.40¡ Ó1.00 PIN1 147.58¡ Ó0.30 138.20¡ Ó0.30 ITO Film T=0.188mm 14.50¡ Ó 0.50 50.00¡ Ó0.50 136.00¡ Ó0.20 (AA) ITO Glass T=1.10mm 3.50¡ Ó0.30 137.00¡ Ó0.20 (VA) 7.81¡ Ó0.20 147.98¡ Ó0.20 (TP) 7.31¡ Ó0.20 0.300¡ Ó 0.3 0.30¡ Ó 0.30 5.00¡ Ó 0.10 YU XR XL YD 1 2 3 4 LOGIC The non-specified tolerance of dimension is Resistance Touch Panel General Specifications Item Description Driving condition DC5V Operating force 20~100g Linearity max ≤±1.5% >20MΩ,25V(DC) Insulating resistance Light transparence 70% Structure type ITO Film/ITO Glass(F/G) Surface Hardness 3H typ Pen Hitting Durability (with the silicon rubber) >1000,000 times X resistance Y resistance 450~1100Ω 200~600Ω 0.3mm.
MDT1010GIHR-HDMI 价格&库存
很抱歉,暂时无法提供与“MDT1010GIHR-HDMI”相匹配的价格&库存,您可以联系我们找货
