Universal development board
for ARM MCUs
for
1611
Different ARM MCUs supported
ON-BOARD
USB & WiFi debugger
5 x mikroBUS socket
for 650+ different click boards
WORLD’S FIRST
DEBUGGER OVER WiFi
On-board debugging and programming over WiFi
Fusion for ARM development board integrates first-ever embedded
debugger/programmer over WiFi. Enjoy cable-free world!
*CODEGRIP WiFi License is available as an add-on feature.
Access anywhere, under any circumstances at
anytime
Unlimited possibilities for development, you can place the
development board in almost any hardly accessible places such as
hazardous environment, agricultural setting, and high-rise buildings
while still retaining full debugging and programming access.
Redefine technical support
Replicating user’s hardware has always been a challenge, debugging
over WiFi enables technical support to directly access user’s hardware.
Do more with less effort!
ON-BOARD CODEGRIP
DEBUGGER
Free on-board debugger &
programmer over USB-C
The on-board CODEGRIP USB-C debugger & programmer, currently
supports for more than 1100 microcontrollers from different vendors.
Lifetime free updates with new microcontrollers and vendors.
CODEGRIP Suite
CODEGRIP Suite is a powerful software suite that offers complete
control over the Fusion for ARM v8 development board. It is used to
intelligently manage programming and debugging tasks, as well as
various other options and settings of the development board.
Plug and play
USB-C debugger enables effortless programming/debugging
over generic USB driver connection without the need for
additional driver support.
NEW MCU CARD
STANDARD
Intuitively designed socket
Fluent design offers high-speed connector, low-profile
integration of the MCU card with the development board, the
socket has (female/male) connectors that eliminates wrong
insertion. The MCU card has standardized dimensions that can
support various number of pin varieties for specific hardware
requirement. Such a modular approach allows flexibility in
selecting the MCU type, regardless of the pin number or the
specific hardware requirements.
Freedom of choice
The new MCU card standard allows to simultaneously use from
low pin count to high pin count microcontrollers on one board.
Multi-vendor support
The MCU Card standard makes it possible to use MCUs
regardless of their vendor or manufacturer.
One MCU card standard supports multiple ARM MCU families:
STM32, Kinetis, TIVA, CEC, and MSP.
Support for even more vendors is coming!
More than 350 MCUs
regardless of their vendor.
supports multiple
architectures ARM, PIC32,
dsPIC, PIC, AVR through
different vendors: Microchip,
ST, NXP, TI and many more
yet to come!
NEW DISPLAY BOARD
STANDARD
Display board connector
The Fusion for ARM v8 development board features new display
connector. New connector has a female 2x20-pin support, which
allows different screen sizes as well as technologies.
Screen technology
Display board connector can be attached with various screen
technologies, currently available are the TFT capacitive screen
boards which offer a wide selection of screen sizes and resolutions.
Future iterations will offer technologies such as OLED and e-Ink.
Screen sizes
Check out how it looks with different screen sizes and
resolutions, choose from; TFT board 3 with a 3.5“ display with
the resolution of 320x240 pixels, TFT board 4 with a 4.3“ display
with the resolution of 480x272 pixels, TFT board 5 with a 5“
display with the resolution of 800x480 pixels, TFT board 7 with a
7“ display with the resolution of 800x480 pixels.
IDEAL FOR RAPID
PROTOTYPING
Rapid prototyping allows the engineer to take the most
efficient and effortless way, to envision the design ideas,
capabilities and limitations through measurable means. This
is the crucial eliminating factor for time to market pressure.
Improved mikroBUS™ sockets
The Fusion for ARM v8 offers five improved mikroBUS™ sockets,
where you can place any of the 600+ different Click boards™.
Adding, the infinite amount of possibilities with the largest
add-on board selection in the world.
Ready-to-use Click boards™
With more than 600 Click boards™ available, they are the
fastest-growing range of add-on boards in the world, which are
standardized by pinout and size.
They enhance rapid development and accelerate time to market.
These ready-to-use boards require no additional hardware
configuration.
Engineered to deliver the best performances for the used
components, they save developers of testing and troubleshooting
often associated with the prototyping phase.
Endless modularity
The ready-to-use Click boards™ are saving time and money by
offering complete solutions of hardware and software, instead of
developing them from scratch.
Choose one of hundreds of Click boards™ out of these categories:
mixed signal, wireless connectivity, storage, interface, displays,
human-machine interface, adapter, clock and timing, motor
control, power management and audio & voice.
FIRST CLASS POWER
SUPPLY
State of the art power supply
Fusion for ARM v8 offers state of the art power supply with constant
power delivery and unprecedented flexibility. The power supply module
is carefully designed to regulate, filter and distribute the power noise
free.
In addition, it features convenient capacitive POWER and RESET
buttons.
Uninterruptable power supply
Power supply unit supports a wide range of power sources that can
be used: External 12VDC, USB, and a Li-Po/Li-ION battery. It also
supports UPS functionality.
When powered by the battery, it offers an ultimate degree of
autonomy.
Programmable voltage output
The power supply module supports programmable voltage output
which can be used as a reference for various purposes, including A/D
or D/A converters, comparators, and any other peripherals that require
or can use an external reference voltage. The programmable voltage
output can be controlled over the CODEGRIP Suite.
PREMIUM USER
EXPERIENCE
Robust by design
The Fusion for ARM v8 development board is 3.2 mm thick, sturdy and
durable design eliminates the board from bending when working with
it. All the components of the board are produced on surface mounted
technology standard, enabling sturdy, compact design.
Sturdy on its feet
Every detail is carefully thought through, from the height-adjustable
stand with non-slip pads, to ergonomic design, which allows
comfortable project development.
Clear intuitive layout
Fusion for ARM features clean and elegant design, allowing
the user to instantly understand how to set it up and how to
easily tune it according to needs. The development board is
divided into several sections, arranged so that all the related
interactive components such as switches, buttons, indicators,
and connectors, are logically positioned and grouped together.
APPRECIATE YOUR TIME
