SigFox 3 click
PID: MIKROE‐3163
Weight: 30 g
SigFox 3 click is a device which carries the SN10-13, a fully integrated Sigfox™ certified
module by InnoComm, allowing connection to a low power wide area network (LPWAN)
that enables communication utilizing the Industrial, Scientific, and Medical (ISM) radio
frequency band. The Sigfox network is a star topology network, specifically designed for
the Internet of Things (IoT) applications. It uses an ultra-narrow frequency band, able to
penetrate through the objects and cover large distances, making it a perfect choice for
various industry-specific applications, such as the sensors networking in agriculture.
Note: Sigfox 3 click is intended to be used in the RCZ3 (Japan).
More information about the Sigfox network coverage, and other related information can
be found at the official Sigfox site.
Also, if you are looking for a Sigfox click that covers other regions, please check out
our other Sigfox click products.
This Click board™ offers all that is needed to integrate a Sigfox network connectivity
into a design. Besides the SN10-13 module itself, it offers the industry-standard SPI
communication protocol and an onboard SMA connector, used to connect the
appropriate 868MHz antenna. With its low power consumption, SigFox 3 click can be
used on a battery-operated platform for a very long time, without replacing the battery.
How does it work?
appropriate antenna. With its low power consumption, SigFox click can be used on a
The Click board™ is equipped with the SN10-13 Sigfox™ certified module, manufactured
by InnoComm Mobile Technology Corporation. The hearth of this module is the
NXP OL2385, a sub-GHz wireless transceiver System-on-Chip (SoC). The communication
between the SN10-13 module and the host MCU is performed over the SPI. An
additional AK pin is used to signal the command acknowledgement. There is a number
of commands available, which are all sent in a specific format. Each data packet
transferred via the SPI bus contains the number of bytes to be sent, the command itself,
and the data payload (if there is one). Upon the successful command, the AK pin will
indicate the response. This pin is routed to the mikroBUS™ AN pin.
In addition, commands return the status over the SPI. If a command is successful, a
status of 0 is returned, for example. Different status responses have different meaning.
Some commands may return various error codes, indicating a certain condition of the
signal chain. For example, a command might get accepted by the module, but refused
by the remote base station (station not reachable, and similar). All the commands are a
part of the firmware API offered by the module, over the SPI interface. However, the
library which comes with the SigFox click contains functions that encapsulate all the
necessary commands and handle the responses, offering simplified programming
interface, in the familiar MikroElektronika compilers environment.
The module can be reset over the RST pin of the mikroBUS™. This pin is pulled to a
HIGH logic level internally. Setting it to a LOW logic level will perform a hardware reset
of the SN10-13 module.
The Sigfox network operates using a public frequency bandwidth, defined by the
regional radio regulations. Sigfox SN10-13 module is verified and Japan MIC approved.
In the Japan region (RCZ3), the Sigfox network operates at 923MHz frequency band.
This network is a star topology type of network and requires a base station which
collects the data from the connected nodes and sends it to the Sigfox cloud for further
processing and distribution.
The nodes can be as far as 1000m from the base station, depending on the regional
Sigfox network frequency (the official information about the network coverage can be
found on the Sigfox site). Node objects can be various temperature and humidity
sensors, parking lot sensors, etc. The node objects communicate with the base using the
Differential Phase Shift Keying (DPSK) communication method. Small messages with the
data payload as low as 12 bytes are transmitted several times per day, allowing
conservative power consumption. The ultra-narrow frequency band allows the TX power
to stay really low, saving even more power and allowing batteries to last a few years.
This is very well suited for various industrial applications, such as the agriculture
industry, where many sensor nodes are often scattered over a wide area and are hard to
reach for a frequent battery replacement.
Once it collects the data, a base station will decode it and send it to the Sigfox cloud.
The data is processed and pushed back to the user application. While the uplink
(information transfer from the node to the cloud) is performed using the more robust
and efficient DPSK communication method, the downlink (information transfer from the
cloud to the application) uses the Frequency Shift Keying (FSK), which is less robust than
the DFSK and uses broader frequency range. Typically, the interference is not a big
concern for the downlink. The key difference between similar, cellular network based IoT
network solutions, is that all stations in range will pick up the node signal and forward it
to the cloud, not just a single station.
The Sigfox cloud is unique and all the base stations are connected to it. This type of
centralized approach can have some inherited benefits. For example, it is possible to
track goods, by accessing data sent by another station in a different part of the country,
or even a different country. With its global Low Power Wide Area network, Sigfox is a
true Internet of Things.
Specifications
Type
RF Sub 1GHz
SigFox click offers connectivity to the SigFox network. It can be used for a wide
Applications
range of IoT applications, which require large area coverage, such as the
agriculture industry applications, parking lot applications, goods tracking
applications, and similar
On-board
modules
SN 10-13 Sigfox certified module, by InnoComm
Official Sigfox network certified module onboard, simplified software functions
Key Features
allow rapid development, robust IoT networking with very wide area coverage,
Sigfox cloud allows access to distant base stations and nodes, and more
Interface
SPI
Input Voltage
3.3V
Compatibility
mikroBUS
Click board
L (57.15 x 25.4 mm)
size
Pinout diagram
This table shows how the pinout on SigFox 3 click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
ACK OUT
AK
1
AN
PWM
16
NC
Reset
RST
2
RST
INT
15
NC
CS
3
CS
RX
14
NC
SPI Clock
SCK
4
SCK
TX
13
NC
SPI Data OUT
SDO
5
MISO
SCL
12
NC
SPI Data IN
SDI
6
MOSI
SDA
11
NC
Power supply
3.3V
7
3.3V
5V
10
NC
Ground
GND
8
GND
GND
9
GND
Chip Select
Pin
Notes
Ground
Onboard connectors and indicators
Label
Name
Description
PWR
PWR
Power LED indicator
ANT
ANT
SMA antenna connector
Software support
We provide a demo application for SigFox 3 Click on our Libstock page, as well as a
demo application (example), developed using MikroElektronika compilers. The demo
can run on all the main MikroElektronika development boards.
Library Description
The library contains basic functions for controlling the click board.
Key functions:
int32_t sigfox3_init() - Function for initializing the sensor.
int32_t sigfox3_wakeUp() - Function for waking up the sensor from the sleep mode.
int32_t sigfox3_sleep() - Function for placing sigfox to the low power mode.
Example description
Click board wakes up from sleep. Some tests are performed. After the tests and after the
data has been sent and received from the network the click board is placed into the
sleep mode to its low power mode. All events that are executed inside of the application
task are printed to the serial port.
void applicationTask()
char spiFrameACK = 0;
char rData[20];
uint8_t sendPayload[12] = "Test msg";
_status = sigfox3_wakeUp();
if(_status == _SIGFOX3_STATUS_SUCCESS)
mikrobus_logWrite("Wakeup succesfull",_LOG_LINE);
_status = sigfox3_testSpicon(&spiFrameACK);
if(spiFrameACK == 1)
mikrobus_logWrite("SPI test finished succesfully",_LOG_LINE);
mikrobus_logWrite("Sending data to sigfox network",_LOG_LINE);
_status = sigfox3_receiveMessage(&sendPayload[0],&rData[0]);
mikrobus_logWrite("Data received",_LOG_LINE);
mikrobus_logWrite(&rData[0],_LOG_LINE);
else
mikrobus_logWrite("Network error",_LOG_LINE);
else
mikrobus_logWrite("Error in echo frame",_LOG_LINE);
else
mikrobus_logWrite("Error in wakeup",_LOG_LINE);
_status = sigfox3_sleep();
mikrobus_logWrite("Sleep entered",_LOG_LINE);
else
mikrobus_logWrite("Error entering sleep",_LOG_LINE);
Delay_ms(5000);
The full application code, and ready to use projects can be found on our Libstock page.
Other MikroElektronika libraries used in the example:
SPI Library
UART Library
Conversions Library
C_String Library
Additional notes and information
Depending on the development board you are using, you may need USB UART
click, USB UART 2 click or RS232 click to connect to your PC, for development systems
with no UART to USB interface available on the board. The terminal available in all
MikroElektronika compilers, or any other terminal application of your choice, can be
used to read the message.
mikroSDK
This click board is supported with mikroSDK - MikroElektronika Software Development
Kit. To ensure proper operation of mikroSDK compliant click board demo applications,
mikroSDK should be downloaded from the LibStock and installed for the compiler you
are using.
For more information about mikroSDK, visit the official page.
https://www.mikroe.com/sigfox‐3‐click 10‐2‐18
