Temp-Log 3 Click
PID: MIKROE‐3326 Weight: 23 g
Temp‐Log 3 click is a temperature measuring Click board™ featuring the
MCP9843 IC, an accurate temperature sensor IC with integrated EEPROM.
Besides the thermal sensor, this IC is equipped with additional 256 bytes of
EEPROM. This can be a very useful option for some applications: it allows
any data to be stored within the same IC, so no additional EEPROM IC is
required. This can simplify the design, reducing the number of additional
components. The thermal sensor itself includes some great features such as
the programmable interrupt engine, measurement range from -20°C to
+125°C, accuracy up to ±1°C typically, and more.
Temp-Log 3 click is supported by a mikroSDK compliant library, which
includes functions that simplify software development. This Click board™
comes as a fully tested product, ready to be used on a system equipped with
the mikroBUS™ socket.
The MCP9843 IC meets JEDEC specification JC42.4‐TSE3000B3 and JC42.4‐TSE2002B3,
allowing it to be used as a thermal sensor for memory modules. The MCP9843 is designed
specifically for DRAM DIMMs (Dual In‐line Memory Modules), allowing the Serial Presence
Detect (SPD) feature. However, its use is not limited only to memory modules. The
presence of EEPROM can be utilized for many different tasks: recording of temperature
peaks, storage of various thermal event alerts, and similar. This makes Temp‐Log 3 a great
choice for development of various embedded applications based on temperature
measurement and data logging.
How does it work?
Temp‐Log 3 click is equipped with the MCP9843 IC, a temperature sensor with EEPROM,
by Microchip. This IC is used to convert the temperature measurement into digital
information. Besides the thermal sensor, this IC also features 256 bytes of EEPROM on the
same die. It is compliant with the JEDEC specification JC42.4‐TSE3000B3 and JC42.4‐
TSE2002B3 since it is designed specifically for DRAM DIMMs (Dual In‐line Memory
Modules), allowing the Serial Presence Detect (SPD) feature. However, it is not limited only
to this role: it can be used as a very accurate general‐purpose thermometer with the added
benefit of integrated EEPROM, reducing the number of physical ICs required to design a
temperature logging application. Temp‐Log 3 click utilizes the I2C serial interface (SMBus
compatible), which allows it to be used in a wide range of applications.
The temperature sensor section includes all the features typically found on such ICs. Most
of its interrupt engine features are very similar (or identical) to features found in Thermo 8
click, which is based on the MCP9808 IC. This includes the interrupt and thermometer
modes, alert pin configuration, hysteresis of the temperature thresholds, critical
temperature alert feature, and so on. The EVENT pin of the IC is routed to the INT pin of the
Click board™. It is pulled to a HIGH logic level by a resistor, so the polarity should be
programmed accordingly, the same as in the case of Thermo 8 click. However, there are
some minor differences including the EEPROM section, which will be discussed.
The MCP9843 features the CAPABILITIES register, unlike the MCP9808 IC. This register is a
read‐only register and it provides some general information, such as the factory‐specified
accuracy in the upper‐temperature range (+75°C to +95°C and +40°C to +125°C),
measurement range, resolution, and other parameters of the sensor. Its description, along
with the description of other registers, can be found in the MCP9843 datasheet.
Although the output temperature register is of the same width as the one used in MCP9808
(16 bits), there are 12 bits of thermal data available along with the sign bit, in the 2’s
complement format. All the user‐configurable registers in the MCP9843 are 16 bits wide.
However, not all 16 bits are used, in most cases.
Both the temperature and the EEPROM section have their own I2C address. The I2C
address is determined by four fixed bit values, while the last three bits (LSBs) are
determined by the logic states applied to A2, A1, and A0. While A2 and A1 address are
hard‐wired to a LOW logic level on this Click board™, the value of the A0 address bit can be
changed by switching the SMD jumper labeled as ADDR SEL to either 0 (tied to GND) or 1
(tied to VCC). The datasheet of the MCP9843 offers a table with the content of these four
bits for each section of the IC.
By switching the SMD jumper labeled as VCC SEL, the logic voltage level of the I2C bus can
be selected between 3.3V and 5V. This allows Temp‐Log 3 click to be interfaced with both
3.3V and 5V MCUs. Note, however, that the MCP9843 is supplied with power from the
mikroBUS™ 3.3V rail, regardless of the VCC SEL jumper position.
Specifications
Type
Humidity,Temperature
Applications
Temp-Log 3 is a great solution for the development of
On-board
modules
MCP9843 IC, a temperature sensor with EEPROM, by
Microchip
Key Features
A very high measurement accuracy and repeatability,
programmable thresholds and hysteresis, a dedicated
EVENT pin with a programmable function, selectable
resolution, 256 bytes of integrated EEPROM, and more
Interface
I2C
Input
Voltage
3.3V,5V
Click board
size
M (42.9 x 25.4 mm)
Pinout diagram
This table shows how the pinout on Temp‐Log 3 Click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
NC
1
AN
PWM
16
NC
NC
2
RST
INT
15
INT
NC
3
CS
RX
14
NC
NC
4
SCK
TX
13
NC
NC
5
MISO
SCL
12
SCL
I2C Clock
NC
6
MOSI
SDA
11
SDA
I2C Data
Power Supply
3V3
7
3.3V
5V
10
5V
Ground
GND
8
GND
GND
9
GND
Alert OUT
Power Supply
Ground
Onboard settings and indicators
Label
Name
Default
Description
PWR
PWR
JP1
VCC SEL
Left
Logic voltage level selection: left position
3.3V, right position 5V
JP2
VCC SEL
Left
I2C slave address selection: left position 0
(GND), right position 1 (VCC)
Power LED indicator
Software support
We provide a library for the Temp‐Log 3 Click on our LibStock page, as well as a demo
application (example), developed using MikroElektronika compilers. The demo can run on
all the main MikroElektronika development boards.
Library Description
The library performs a control of the Temp‐Log 3 Click board. There are a functions that
offer a choice to measure the ambient temperature and set a temperature limit values to
generate alarm. The library also can save a desired configurations or temperature values to
the EEPROM, which has size of 256 bytes. For more details check documentation.
Key functions:
T_TEMPLOG3_RETVAL templog3_writeReg( uint8_t regAddr, uint16_t dataIn ) - Function
writes a 16bit data to the desired register.
T_TEMPLOG3_RETVAL templog3_getTemp( uint8_t tempSel, T_TEMPLOG3_DEG *tempOut ) -
Function gets a temperature value from the desired temperature register calculated to the
Celsius degrees.
T_TEMPLOG3_RETVAL templog3_setTemp( uint8_t tempSel, T_TEMPLOG3_DEG tempIn ) Function sets a desired temperature register on the desired value calculated to the Celsius
degrees.
void templog3_eepromByteWrite( uint8_t regAddr, uint8_t dataIn, uint8_t eepromMode
) - Function writes a one byte data to the EEPROM including/excluding a write protection.
Examples description
The application is composed of the three sections :
System Initialization - Initializes peripherals and pins.
Application Initialization - Initializes I2C interface and performs a device configuration for
properly working. Also sets the temperature limit to the desired values.
Application Task - (code snippet) - First ensures that the minimum conversion time is met, and
then reads the ambient temperature calculated to the Celsius degrees. Also checks the limit
status and shows a message when some limit condition is met. Note : The temperature range
that can be measured or written is from -40 to +125 Celsius degrees. The user can change the
measured temperature resolution, but the range remains the same. The limit temperature
resolution is always a 10bit, or 0.25 Celsius degrees. If user wants to enable the EEPROM
Write Protection, the A0 pin on the device must be set to the high voltage level.
void applicationTask()
templog3_waitConvDone();
retStatus = templog3_getTemp( _TEMPLOG3_TEMP_AMBIENT_REG, &temperature );
FloatToStr( temperature, text );
floatCut();
mikrobus_logWrite( "** Ambient temperature is : ", _LOG_TEXT );
mikrobus_logWrite( text, _LOG_TEXT );
logUnit();
mikrobus_logWrite( " **", _LOG_LINE );
checkLimitStatus();
Delay_ms( 300 );
Additional Functions :
floatCut - Makes that float values be rounded on two decimal places.
logUnit - Writes a Celsius degrees symbol on uart terminal.
checkLimitStatus - Checks the limit status for each temperature reading cycle and writes a
message on uart terminal when some limit condition is met.
The full application code, and ready to use projects can be found on our LibStock page.
Other mikroE Libraries used in the example:
Conversions
I2C
UART
Additional notes and informations
Depending on the development board you are using, you may need USB UART click, USB
UART 2 click or RS232 click to connect to your PC, for development systems with no UART
to USB interface available on the board. The terminal available in all
MikroElektronika compilers, or any other terminal application of your choice, can be used
to read the message.
https://www.mikroe.com/temp‐log‐3‐click/2‐14‐19
