MIKROE-1969
MIKROE-1969
    MIKRO
    CLICKER 2 CEC1302 EVAL BRD
MIKROE-1969 数据手册
Page 1 of 7 All the inventions waiting to happen... clicker 2 is a battery-powered click™ board two-seater. Inventing and putting together fully-functional standalone gadgets is now just 1% perspiration, and 99% inspiration! Thousands of possibilities 19110 CLICK BOARD COMBINATIONS With two mikroBUS™ sockets on clicker 2, you can take advantage of the huge potential of click™ boards, the constantly expanding range of over 196 add-on boards. Blend different functionalities together and come up with new and original inventions. That’s just two clicks and your project is half-way done. Go ahead and play with a few ideas right away: Page 2 of 7 Security ensured This clicker 2 is powered by CEC1302, a 32-bit ARM®-Cortex® MCU from Microchip that integrates a cryptographic engine that provides high level security features. • Authentication with public key algorithms (RSA-2048) • Integrity with Secure Hash Algorithms (SHA-1, SHA-256) • Privacy with symmetric encryption (AES) • Entropy with true Random Number Generator CEC1302 has 128 KB SRAM, 32 KB boot ROM, and runs at 48MHz. Page 3 of 7 Powering Your Inventions Focus on your main idea because clicker 2 will take care of the details for you: your prototype already has a power management system in place. The onboard LTC®3586-1 IC will provide 3.3V or 5V to the clicks. It turns the USB port into a battery charger. For convenience, clicker 2 for CEC1302 features a reset button and an ON/OFF switch (you can also connect an external ON/OFF switch). Page 4 of 7 Expanding Your Ideas No idea is too big for clicker 2. Let your train of thought lead you anywhere. Consider all options, explore all directions. More click boards? Additional electronics? Done and done. clicker 2 has the same pocket-size form factor and the same pair of 1x26 connection pads as mikromedia boards. This makes it compatible with mikromedia shields letting you expand your device any way you want. Page 5 of 7 MIKROE-1154 MIKROE-938 MIKROE-767 MIKROE-712 mikroBUS shield Connect shield PHOTO shield Battery Boost shield Hardware Debugging Efficiently erradicate any bugs and iron out your code until it’s wrinkle free and your clicker 2 device works perfectly—use mikroProg™ for CEC1302. It’s a fast hardware debugger and programmer that exploits the MCU’s integrated encryption module, enabling secure firmware updating. Page 6 of 7 Tech specs Pushbuttons, signal LEDs, jumpers, pads for connecting an external ON/OFF switch, here are all the bits and details at your disposal: Processor Connectivity - CEC1302 has 128 KB SRAM - 52 programmable GPIOs - 32 KB boot ROM - 2 mikroBUS host sockets - 48MHz - USB Mini-B connector Documentation and software Download Shematic [6.43MB] Download UART Bootloader [1.05MB] Download mikroProg Suite for ARM [2.3MB] Page 7 of 7 What’s in the package? Order Now MIKROE-1969 clicker 2 for CEC1302 http://www.mikroe.com/cec1302/clicker-2/ 5/2/2016
MIKROE-1969 价格&库存
很抱歉,暂时无法提供与“MIKROE-1969”相匹配的价格&库存,您可以联系我们找货
MIKROE-1969
