MIKROE-2046
MIKROE-2046
    MIKRO
    模块
    WiFi 802.11b/g/n RF 收发器模块 2.4GHz 集成式,跟踪 通孔
MIKROE-2046 数据手册
      WiFi 7 click PID: MIKROE-2046     WiFi 7 click carries the ATWINC1510‐MR210PB IEEE 802.11 b/g/n module, specifically optimized for low‐ power IoT applications. The click is designed to run on a 3.3V power supply. It communicates with the  target microcontroller over SPI interface, with additional functionality provided by the following pins on  the mikroBUS™ line: PWM, INT, RST.    ATWINC1510‐MR210PB features The ATWINC1510-MR210PB is a low-power consumption 802.11 b/g/n module which is specifically optimized for low-power IoT applications. The module has a Cortus APS3 32-bit processor. This processor performs many of the MAC functions, including but not limited to association, authentication, power management, security key management, and MSDU aggregation/de-aggregation. In addition, the processor provides flexibility for various modes of operation, such as STA and AP modes. Module current consumption The table below describes the current consumption of the ATWINC1510-MR210PB module: Additional pins Additional pins on the WiFi 7 click, besides the ones on the mikroBUS™ line: Key features    ATWINC1510‐MR210PB   o IEEE® 802.11 b/g/n 20MHz solution  o Integrated PCB antenna  o Supports IEEE 802.11 WEP, WPA, WPA2 Security  SPI interface  3.3V power supply  Specification  Type Applications On-board modules Wi-Fi Optimized for low power IoT applications ATWINC1510-MR210PB IEEE® 802.11 b/g/n 20MHz solution, integrated PCB antenna, supports IEEE 802.11 WEP, WPA, WPA2 Security Interface SPI Power Supply 3.3V Compatibility mikroBUS Click board size M (42.9 x 25.4 mm) Key Features   Pinout diagram This table shows how the pinout on WiFi 7 click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes    Pin  Pin Notes  mikroBUStm  Not connected  NC  1 AN  Active‐Low Hard Reset  RST  2 RST Chip select  CS  3 PWM 16 EN Module Enable  INT  15 INT Device Interrupt output  CS  TX  14 NC Not connected  SPI Clock  SCK  4 SCK RX  13 NC Not connected  SPI Master Input Slave Output  MISO  5 MISO SCL 12 NC Not connected  SPI Master Output Slave Input  MOSI  6 MOSI SDA 11 NC Not connected  Power supply  +3.3V  7 3.3V 5V  10 NC Not connected  Ground  GND  8 GND GND 9 GND Ground  Programming Code examples for WiFi 7 click, written for MikroElektronika hardware and compilers are available on Libstock. Code snippet The following code snippet shows the default main function for all examples. 01 void main(void) 02 { 03 systemInit(); 04 printf("Project built for Click Boardrn"); 05 printf("Starting driver initialization...rn"); 06 07 hal_wifi7_init(); 08 m2m_wifi_init(); 09 while (1) 10 { 11 ApplicationTask(); 12 m2m_wifi_task(); 13 } 14 }                                                          https://shop.mikroe.com/click/wireless‐connectivity/wifi‐7 6‐6‐17
MIKROE-2046 价格&库存
很抱歉,暂时无法提供与“MIKROE-2046”相匹配的价格&库存,您可以联系我们找货
MIKROE-2046
  • 1+307.872401+39.83152
