MCP2003B click
PID: MIKROE-2227
MCP2003B click is a mikroBUS™ add-on board with a bi-directional LIN transceiver.
It’s a physical interface to automotive and industrial LIN systems, in accordance to the LIN Bus
Specifications Revision 2.2, SAE J2602 and ISO 17987. This standard requires that all nodes in
the system are to be connected through a LIN bus. Up to 15 slave devices can be connected to
a single master.
The click has three onboard screw terminals for connecting the transceiver to a LIN network
(three wires: LIN, VBB and GND).
MCP2003B click communicates with the target board MCU through the mikroBUS™ UART
interface (RXD, TXD), with additional functionality provided by the VRENDIV and LWAKE pins.
Extra pins for LWAKE, CS, and TX and RX are also available above the mikroBUS™.
The board is designed to use a 3.3V power supply only.
Downloads
MCP2003B click Examples
MCP2003B click Schematic
Type
LIN
Applications
Prototyping sensor networks for vehicles
On-board
modules
Bi-directional LIN transceiver
Key Features
MCP2003B IC, Supports baud rates up to 20 Kbaud
Key Benefits
High immunity to RF disturbance, ESD, EMI, Multiple operating modes,
Compliant with LIN Bus Specs revision 2.2
Interface
GPIO,UART
Input Voltage
3.3V
Compatibility
mikroBUS
Click board size
M (42.9 x 25.4 mm)
from Microchip.
Features and usage notes
LIN (Local Interconnect Network) is a serial network protocol used for communication
between components in vehicles (used in conjunction with CAN).
LIN Bus Specifications Revision 2.1 and SAE J2602. This standard requires that all
nodes in the system are to be connected through a LIN bus. Up to 15 slave devices can
be connected to a single master.
The device has four operating modes: power-down (everything except the wake-up pin
is shut down), ready (receiver powered up, transmitter disabled), operation (all internal
modes operational), and transmitter (when transmitter is disabled).
Programming
This is a simple example of LIN Communication, the master sends data, the first time
the slave just receives the data, the second time the slave responds from the response
buffer.
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
#include
#include "lin.h"
sbit tx_pin at LATF4_BIT;
void main()
uint8_t send_buffer[10] = {0};
uint8_t recv_buffer[10] = {0};
uint8_t response_buffer[10] = {0};
UART2_Init( 9600 );
delay_ms(300);
send_buffer[0]
send_buffer[1]
send_buffer[2]
send_buffer[3]
send_buffer[4]
'H';
'E';
'L';
'L';
'O';
response_buffer[0]
response_buffer[1]
response_buffer[2]
response_buffer[3]
response_buffer[4]
response_buffer[5]
response_buffer[6]
response_buffer[7]
'H';
'E';
'L';
'L';
'O';
'B';
'C';
'K';
lin_begin(9600);
lin_hal_init();
lin_send(50,send_buffer,5,2);
lin_slave_receive(50,recv_buffer,2,0);
lin_slave_receive(50,response_buffer,2,1);
while(1);
Code examples that demonstrate the usage of MCP2003B click with MikroElektronika
hardware, written for mikroC for ARM, and PIC32 are available on Libstock.
https://www.mikroe.com/mcp2003b-click 3-8-18
很抱歉,暂时无法提供与“MIKROE-2227”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+187.798401+23.91860
- 国内价格 香港价格
- 1+178.257371+23.16500
