MIKROE-2228
MIKROE-2228
    MIKRO
    MCP25625 CANbus 接口 mikroBUS™ Click™ 平台评估扩展板
MIKROE-2228 数据手册
    MCP25625 click PID: MIKROE-2228 Weight: 33 g   MCP25625 click is a mikroBUS™ add-on board carrying a Microchip CAN controller with an integrated transceiver. It meets the automotive requirement for high speed operation (up to 1 Mb/s). Named after the main chip, MCP25625 click also has a RS232 port, which is a standard connector for  CAN communications. Additionally, the two CAN wires (CANL and CANH) can also be connected directly  through two pins on the right edge of the board.  The click communicates with the target MCU through the SPI interface — although there are additional  options that take the load off the target board MCU. To that end, all 16 mikroBUS™ pins are connected.  There’s a clock output, a Request To Send, an Interrupt, standby, reset and more. MCP25625 click can  work with both 3.3V or 5V logic levels.  Type CAN Applications MCP25625 click also with RS232 port allows CAN communications On-board modules Microchip CAN controller Key Features Operating speeds up to 1 Mb/s, SPI interface (up to 10 MHz Clock speed) with additional pins Key Benefits Interface with a lot of options to offloads target board MCU, Meets requirements of automotive industry (speed, EMC, ESD) Interface SPI Power Supply 3.3V or 5V Compatibility mikroBUS Click board size L (57.15 x 25.4 mm) MCP25625 click is a mikroBUS™ add-on board carrying a Microchip CAN controller with an integrated transceiver. It meets the automotive requirement for high speed operation (up to 1 Mb/s). Features and usage notes MCP25625 click has two pairs of onboard jumpers (zero ohm resistors). One is for choosing the IO voltage. The other is for configuring whether the STB pin will be used to control the click’s operating mode (normal or standby), or if it will go into normal mode as soon as it’s powered up. Here’s a list of key features of MCP25625, taken from the data sheet: General Features:      Stand‐Alone CAN2.0B Controller with Integrated CAN Transceiver and Serial Peripheral Interface  (SPI)  Up to 1Mb/s Operation  Very Low Standby Current (10 μA, typical)  Up to 10 MHz SPI Clock Speed  Temperature Ranges:   o Extended (E): ‐40°C to +125°C  CAN Controller Features:         ImplementsCAN2.0B(ISO11898‐1)  Three Transmit Buffers with Prioritization and Abort Feature  Two Receive Buffers  Six Filters and TwoMasks,with Optional Filtering on the First Two Data Bytes  Supports SPI Modes 0,0 and 1,1  Specific SPI Commands to Reduce SPI Overhead  Buffer Full, and Request‐to‐Send Pins Configurable as General Purpose I/O  One Interrupt Output Pin  Programming The following code snippet shows how to change the device's operating mode and checks the status register for confirmation. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 int mcp25625_mode ( can_opmode_t mode ) { can_ctl.reqop = mode; can_ctl.mask = CAN_REQOP; mcp25625_hw_ctl_update( ( void* )&can_ctl ); if( mcp25625_hw_ctl_get( ( void* )&can_stat ) ) if( can_stat.opmod != mode ) return MCP25625_CTL_ERR; return MCP25625_OK; } Code examples that demonstrate the usage of MCP 25625 click with MikroElektronika hardware, written for mikroC for PIC are available on Libstock. https://shop.mikroe.com/click/interface/mcp25625 6-13-17
MIKROE-2228 价格&库存
很抱歉,暂时无法提供与“MIKROE-2228”相匹配的价格&库存,您可以联系我们找货
MIKROE-2228
  • 1+255.702261+33.11800
库存:5
MIKROE-2228
  • 1+231.57250
  • 5+226.93834
库存:41
